Two shields?
Max Metz
Two shields?
Post by Max Metz » Sun Jun 03, 2012 3:43 pm
As someone who is a little baffled by the electronics, like a lizard in a swimming race, is it possible to run two stepper shields concurrently on the same Aduino, in my case the machine kit will likely arrive with x,y and z controllers to fit on and fill a single shield (if my understanding is correct) - can I just add another a, b and c shield with controllers attached in the future?
Thanks in advance for being gentle. :D
Tom Smith
Re: Two shields?
Post by Tom Smith » Sun Jun 03, 2012 4:57 pm
Hi Max -
The Arduino Uno doesn't have enough pins to drive two shields, so far as I know. I welcome correction from the others on the board, however... if you use the buildlog.net shields, you can get 4 axis for use; the grblShield only provides 3. Both are sufficient for the ShapeOko in its cutting capacity.
Out of curiosity, what are you envisioning that would use the the extra a,b,c controllers?
Tom
_______________
ShapeOko1 191
Two shields?
Post by edwardrford » Sun Jun 03, 2012 5:03 pm
If you are looking for an extra axis or two or three then look at tinyG from synthetos (same people that make the grblShield).
Alden (who is a member on this forum) created it, and is very active in its development. tinyG supports a machine with up to 6 independent axis. Plus, its wicked fast. Watch Alden's 'hello world' video on the wiki to see a shapeoko running at 16,000 mm/s. Blazing fast....
Sent from my BlackBerry 9930 using Tapatalk
Max Metz
Re: Two shields?
Post by Max Metz » Mon Jun 04, 2012 3:27 am
Thanks for the reference to the Buildlog shields, much appreciated Tom.
The availability of extra controllers will give me more opportunity to add extra axis capability in the future, particularly the 4th radial axis running along the x or y on the Shapeoko. The additional 5th and 6th axis allow even further expansion, on the head traveling on the z axis. Each additional axis increases the 3d routing capability of the machine when subtracting material.
The other option I suppose is to go the additive route, an extrude head and hotplate, something I have already seen discussed on here. Best regards and thanks again. :D
Max Metz
Re: Two shields?
Post by Max Metz » Mon Jun 04, 2012 3:43 am
Thanks Edward, I have bookmarked the site, the tinyG is a bullet - makes the Shapeoko go like a rat up a drainpipe. The accuracy too, displayed in the spirograph simulation video is pretty impressive - particularly when the cutter ends where it began and instantly lifts. I found myself saying, '...and on a machine just like mine.' Life is cool. :D
