NEMA 23 gShield config
FaVo
Post by FaVo » Thu Oct 02, 2014 6:53 pm
Hi all,
I'm still planing a Shapeoko 2 with NEMA 23 Motors for the X- and Y-axis.
Now I wonder if the following specs would fit to the gShield v5:
Specifications of the NEMA 23 Stepper
  • Size: 56.4 mm square × 56 mm, not including the shaft (NEMA 23)
    Weight: 0.7 kg (25 oz)
    Shaft diameter: 1/4″ (6.35 mm) “D”
    Steps per revolution: 200
    Current rating: 2.8 A per coil
    Voltage rating: 2.5 V
    Resistance: 0.9 Ohm per coil
    Holding torque: 13 kg-cm (180 oz-in)
    Inductance: 2.5 mH per coil
    Lead length: 12 in
I'm completly new to cnc machines and so any help would be great :-)
FaVo
FaVo
Re: NEMA 23 gShield config
Post by FaVo » Fri Oct 03, 2014 8:55 am
Or would this motor fit better?
(and it is a little bit cheaper)
NEMA 23
  • Current: 2.5A
    Voltage rating: 4.5V
    Resistance: 1.8 Ohm
    Inductance: 6,5MH
    Holding torque: 1.8Nm
    Weight: 1.1kg
    Shaft: 6.35mm
    Steps per revolution: 200 (1.8°)
Auzze
Post by Auzze » Fri Oct 03, 2014 12:32 pm
these are the motors i use on my Shapeoko..
http://www.aliexpress.com/store/product ... 14791.html
Holding Torque:
165 Oz-in/110Ncm
Type:
Hybrid
Brand Name:
RATTM MOTOR
Phase:
2
Current / Phase:
2.5A
Certification:
CCC,CE,ISO,ROHS,UL
Step Angle(degrees):
1.8
Model Number:
23HS6430
Model Number:
23HS6403
Name:
NEMA23 stepper motor
Size:
57x57x56mm
Lead wire:
4PCS
Auzze
Shapeoko #1996F w/ double MakerSlide (500mm) X-Axis, (750mm) Y upgrades, Acme Screw Z-axis, ¼″ drive shaft, Outside belts, cable drag chain.
http://oz3dprint.info/
Post by cvoinescu » Fri Oct 03, 2014 9:02 pm
The second one is a better fit, because of the lower current and higher impedance. Ideally, you would buy one with a current rating between 1.5 and 2 A; if it's over 2 A, your drivers won't be able to supply it, so you won't get the rated torque. (I chose 1.7 A for my NEMA 23 motors because that's a perfect fit for the driver chips on Pololu modules, the gShield, TinyG etc.)
FaVo
Post by FaVo » Fri Oct 03, 2014 10:16 pm
Thanks for your replies.
I learned, that the gShield can provide up to 2.5A with attached cooling. So that would be the absolute maximum.
But another question is the max torque for the belt... I'm using 9mm width belts that should take a bit more torque than the normal belts but what would be a doable torque in general?
There exits a NEMA 23 Motor that has 2.8A but has a torque of 425oz/in (3NM). But I think that would be too much for the belt?`Or can I use this motor and reduce the max torque via the gShield? I'm not sure what's the best way to go...
Post by cvoinescu » Sat Oct 04, 2014 11:29 am
I doubt the belt will be the limiting factor. You don't want a motor heavier than about 700 g, mostly because there's absolutely no point to it. Why would you want to be able to apply, say, 600 N to the gantry or X carriage, when you know that 100 N on your tool will flex the machine too much to be usable?
aeleus
Post by aeleus » Sat Oct 04, 2014 3:09 pm
I'm planning my first build and also thinking of using the gshield with the NEMA 23's listed on inventables. Those motors can draw 2.8A giving 140oz-in.
I understand that the gshield won't provide that current, but my thinking is that I'll have the extra capacity when (or if) I upgrade later.
Any downside of going with the NEMA 23's over the "stock" 17's with the gshield? How much torque can I expect running this way?
ShapeOko 2 #6502 w/ NEMA 23 (140oz) motors (X and Y), Acme Screw Z-axis, Arduino/grblShield/grbl v0.9g
Spindles: Dremel 395; 400W BLDC
FaVo
Post by FaVo » Sun Oct 05, 2014 11:52 am
Since the gShield can only provide 2.5A max you cannot expect the full torque of the motors but that will still be enough.
You can upgrade later to another controller to get the full power out of the motors. You have to think of the y-axis since it has 2 motors on one channel. But that should be ok.
One more thing about the gShield: If you want to use it's maximum current (2.5A) you must install a heat sink! You can't get 2.5A out of it without a heat sink!
The more power your steppers have the better it will be if you plan to upgrade your whole maschine. e.g. double the x and y profiles to get more stiffness... or mount a bigger spindle. Then there will be much more mass to be moved by the motors and a little extra torque will help here...
Like cvoinescu said... it doesn't make sense to use ultra power motors with the stock configuration. That will end up in bending/flexing and loose of accuracy if you use the extra power.
But if you plan to upgrade the x and y axis it can make sense to use bigger motors.
I would say you can use the NEMA 23 steppers listed on inventables without any downside...
aeleus
Post by aeleus » Sun Oct 05, 2014 8:21 pm
Thanks FaVo, that's very helpful.
I just need to figure out what spindle to get now... :?
