Axis USB TB6560 Nema23 3.0A
m_itko
Post by m_itko » Tue Feb 24, 2015 7:41 am
Hello,
Is possible use and config this driver board:
http://www.ebay.com/itm/261491784208?_t ... EBIDX%3AIT
for working whit ShapeOko and dual Nema 23 stepper motor on Y-Axis?
lioramsalem
Re: Axis USB TB6560 Nema23 3.0A
Post by lioramsalem » Tue Feb 24, 2015 8:02 am
it has 4 drivers so I don't see why no.
In Mach3 you can slave one motor to the other and I'm pretty sure it's the same on other software..
LA
ShapeOko 2 #5840 w/ NEMA23, ACME Z axe belt upgrade, limit switches, spindle speed control, 400w brushless spindle, 9mm belts, aluminum bed, eShapeoko X carriage and belts system
Build log: http://www.shapeoko.com/forum/viewtopic.php?f=5&t=3650
m_itko
Post by m_itko » Tue Feb 24, 2015 9:07 am
lioramsalem wrote:it has 4 drivers so I don't see why no.
LA
What electronics use for you machine?
lioramsalem
Post by lioramsalem » Tue Feb 24, 2015 10:46 am
LA
Currently I use a cheap ~10$ BOB wired to the gshield, Mach3 with Gerry's 2010 screenset and VistaCNC MPG.
I really like this setup, especially the semi-automatic tool change and the fact that I only use the computer once, to load the g-code file.
here's a video to the z probing method:
LA
m_itko
Post by m_itko » Tue Feb 24, 2015 12:21 pm
This is my machine:
I work with laptop and want USB driver board working with dual motor for Y-Axis.My Nema 23 does not work well with gShield.
Recommended for me driver board or change Nema 23 with Nema 17!
