Any reason to not use Cat5/Cat6 for my wiring
redrex
Post by redrex » Sat Mar 21, 2015 11:38 pm
Being an IT person I have a need, a compulsion if you will, for cable organization and easy connectivity. So I'm laying out the box for my electronics and it occurs to me, why not just use ethernet cable and connectors to make all of this nice and clean. I run plenty POE equipment and I seem to remember seeing that it can handle up to 36v. Any reason this can't be a safe and reliable wiring setup?
I have a ton of Cat5e and Cat6, shielded and un-shielded.
Open sourcing Moonshine since 1999
Re: Any reason to not use Cat5/Cat6 for my wiring
Post by WillAdams » Sat Mar 21, 2015 11:59 pm
Discussed somewhat here: http://www.shapeoko.com/wiki/index.php/Parts#Wiring
lf memory serves it's okay if you double up the connections. Found it: http://www.shapeoko.com/forum/viewtopic ... 1134#p9150
Woodworker
Post by Woodworker » Sun Mar 22, 2015 12:45 am
They only concern I would have is that is not designed to be repeatedly flexed. That is not to say it would fail but something to consider. Also I would insure a large radius on the cable management to minimize the flex.
redrex
Post by redrex » Sun Mar 22, 2015 4:49 am
Woodworker wrote:They only concern I would have is that is not designed to be repeatedly flexed. That is not to say it would fail but something to consider. Also I would insure a large radius on the cable management to minimize the flex.
Any idea what the gauge was on the wire you used? I'm curious if there is an RJ style adapter that could be used with the 4 wire that they use. I'm just looking for easy, reusable connections for the most part.
Woodworker
Post by Woodworker » Sun Mar 22, 2015 7:48 am
I've never used CAT 5/6 outside of networking. The RJ series of connectors would be prone to failure in dusty vibrating environments. The small springs in the female connector would not last. I have not chosen a wire for my upgrade yet but will be starting the search soon. There are many choices out there for multi wire jacketed cables. As for connectors I will probably stay with what has been used here before, the 4 wire microphone type.
Post by cvoinescu » Mon Mar 23, 2015 4:07 pm
Stranded Cat5/6 cable is often used in DIY CNC, and it works well, especially if it's one of the heavier gauge ones (not the thin kind you often get bundled with home network routers). Use two conductors for each wire.
Do not use RJ45 connectors. They're not designed for that kind of current, and they'll go bad, and kill your drivers too (the drivers are protected against over-current and short-circuits, but not against connecting and disconnecting the load while powered, so your connection must be secure). DE9 connectors (informally known as DB9) are a very good choice; also the so-called "round aviation plugs" on eBay.
footswitch
Post by footswitch » Thu Mar 26, 2015 12:16 pm
cvoinescu wrote:the so-called "round aviation plugs" on eBay
GX16 connectors. In this case with 4 or 8 pins, for 1 or 2 motors respectively.
I love these. The tightening ring is a total win.
Currently assembling eShapeoko #335
