Z Axis reversed
mcdonaldmf
Z Axis reversed
Post by mcdonaldmf » Sun Apr 12, 2015 1:26 am
My Shapeoko 2 works, but the Z axis is reversed, is there a way to fix this with wiring?
Re: Z Axis reversed
Post by WillAdams » Sun Apr 12, 2015 1:34 am
http://www.shapeoko.com/wiki/index.php/ ... _Direction
Any one of these changes will reverse the direction:
swap the two wires of the first pair;
swap the two wires of the second pair;
swap the two pairs between them.[7]
mcdonaldmf
Re: Z Axis reversed
Post by mcdonaldmf » Sun Apr 12, 2015 1:43 am
What color should go to what color? Or do you mean swap the black and green where they go into the Gshield?
Re: Z Axis reversed
Post by WillAdams » Sun Apr 12, 2015 2:28 am
If black and green are the left-most or right-most pairs, yes, they’re a pair and swapping them will reverse the axis.
mikenmel08
Re: Z Axis reversed
Post by mikenmel08 » Sun Apr 12, 2015 12:37 pm
Also ,what version of GRBL are you running? I ask because when I first got my shapeoko going a month ago I was running 0.8 and had to reverse my Z Axis to make it function properly......When I upgraded to the new 0.9 I had to reverse it again back the way it was originally ....
Shapeoko 2 #8233
mcdonaldmf
Re: Z Axis reversed
Post by mcdonaldmf » Sun Apr 12, 2015 11:16 pm
I switched the wires and it's fine now. It's version 8
mikenmel08
Re: Z Axis reversed
Post by mikenmel08 » Wed Apr 15, 2015 2:15 am
Just be ready, when and if you upgrade to the 0.9 you will more than likely have to switch them back...
Shapeoko 2 #8233
