Touch plate and alternatives
Okay, added a section on these to the wiki: http://www.shapeoko.com/wiki/index.php/ ... ouch_Plate
Must admit I’m tempted by the commercial one from Amazon --- at last, something worthwhile to get w/ my Bing reward points.
http://www.amazon.com/Z-Axis-Setting-To ... B00UNXXZAG
Just as a check, my understanding of such a device is:
One homes the machine, then one places the touch plate on either the Wasteboard or the stock (depending on where one wants the reference surface / origin to be), the touch plate lead is then clipped to the endmill, and one enters an appropriate command (or clicks the proper button / engages the correct widget) so as to set the height of the Z-axis — the specific height of the touch plate allows one to do this — that’s why this one is shown as exactly 20mm.
Re: Touch plate and alternatives
Is there a way to set the top Z-axis limit switch’s triggering position to be a positive value? Or is this one of those bad ideas, contrary to good working practices which are unsupportable?
I use a similar gizmo as in the Amazon link. With my gizmo a red light lights up when the CNC bit touches the pad. The pad is "exactly" 2.0 inches above the surface. You have to manually set Z to zero, remove the gizmo, move Z to -2.0 inches, then reset Z to zero. Works like a champ, although manual. It's a bit of a pain to clip one lead to the CNC bit, but that's a pretty small price to pay to get a simple and really accurate way to setting Z to zero at the surface.WillAdams wrote:Is there a way to set the top Z-axis limit switch’s triggering position to be a positive value? Or is this one of those bad ideas, contrary to good working practices which are unsupportable?
This would be a really nifty feature in GRBL, "Auto Setting Z Axis to Zero at Surface". If you change bits a lot, this feature becomes critical.
I hope there is some way to automate. Is it possible for me to help add this feature to GRBL?
Bob
SVEMakerSpaces
SVEMakerSpaces
If I understand things correctly, that's what the probe commands are for.
The one on Amazon is simply a hunk of plastic with a machined piece of metal held by a screw. There is no spring or anything like that to protect your endmill. There are no electronics inside: just the two wires you see. An identical device can be had on eBay for much less, from China (where I'm sure this one originates too).
yeah, basically identical thing available on ebay for about $10 shipped from China (don't ask me how that is possible).
In China it only costs 10 cents to make then you wrap it in newsprint, put US postage on it and give it to a trained rat. The rat scurries onto a cargo ship and hides in a corner. When the ship docks, he takes the package to the nearest post office. In a few days it is at your door. Simply really.
Joking aside, Chinese international postal rates are low ’cause they’re subsidized by the Chinese government, and I believe there’s a favorable cost of living adjustment.
Okay, so this is an electronic device simple enough to make that I should be able to make one. AIUI, one would want:
- a metal plate (conductive, for the endmill to contact)
- a wire which plugs into the probe connection on the micro-controller — one end would have a clip for the endmill, the other would connect to the metal plate / housing
- a housing which would feature an adjustment mechanism to allow one to ensure that the metal plate is held level and at a known distance from the base of the housing (which must be level / flat enough to place on a work surface) and a way to ensure electrical connection for the other lead
Why the adjustment? A fixed touch plate is still "at a known distance from the base of the housing". Not predetermined, but known -- measured with your favorite calipers. As for level, that's not usually a problem, especially not if the housing and the metal part are cut or milled from reasonably flat stock, or turned on a lathe. Those are inherently flatter than most people can adjust them.
