nema 17 heat problem
op117
Post by op117 » Sat Jun 13, 2015 2:24 am
whats the best way to cool down the nema 17 motors?
The ambient temp is around 90F and i have thermal shut at every job, also cooling the air is not a potion for my shop at the moment...
whats the best heat sinks, fans , and config of eater... would be awesome to put a radiator like a h100 with custom blocks on the motors :o :lol:
but whats the most cost effected cooling for this :?:
Re: nema 17 heat problem
Post by WillAdams » Sat Jun 13, 2015 3:25 am
Are you certain it’s the motors shutting down and not the stepper drivers?
- active cooling --- get a fan
- adjust the current, turn it down as much as makes sense
http://www.shapeoko.com/wiki/index.php/ ... he_Current
Jimf
Post by Jimf » Sat Jun 13, 2015 3:52 am
I use small 12volt fans attached to heat sinks. The ones you see used on graphics card.s. They will lower the temperature approximately 20 degrees.
clockit
Post by clockit » Sat Jun 13, 2015 5:28 am
I'm with Will here, I've cut jobs that lasted over 2 hours and never once have my 17's shut down...
Shapeoko 2, Full Kit #7071, Makita RT0701C Router, 1000 x 1000 upgrade, Acme Z Axis w/Nema 17 Belt Drive
op117
Post by op117 » Sat Jun 13, 2015 6:06 am
im thinking of getting
heatsinks
4x http://www.amazon.com/gp/product/B00N41 ... W35WSKZ6W8
cutting to size for motor driver board and the motos thim selfs and
2x http://www.amazon.com/40mmx10mm-Blades- ... +40mm+fans
fans
also i have all ready adjusted the pots on the driver board, but still gettting a shut down....
this is just for fun i made a inventer file for a nema 17 water block:
http://www.filedropper.com/nema17waterblock :lol:
Post by cvoinescu » Mon Jun 15, 2015 6:58 pm
The motors themselves do not have any sort of temperature sensing or overheating cut-out. They can go fairly hot (hotter than you can keep a finger on for more than a second) before they're in danger. If they cut out, it's the drivers that overheat, and cooling the motors will not make a difference. You can reduce the current a little to reduce the motor and driver temperature, but it also reduces torque. What you need is better cooling of your drivers (gShield or whatever you're using). Try to get airflow both over and under the board (e.g. with a fan placed to one side).
