Yes, I meant to respond to you; thanks for catching my mistake and responding anyway.461oceanblvd wrote:Not sure if you meant to respond to me, but I linked the cable I used in the previous post, and plugged it into the 1x6 pin connector in the bottom middle seen here:
So, you are referring to the connector labelled serial_programmer? Did you add the pins on there? I have v2.2 of the controller, and my pins are not there (just the pads).
I saw the cable that you linked to, but I still would like to know how you connected it. The picture on the SparkFun website shows a black wire at one end of the terminal, and a green wire at the other end. Did you connect it to the serial_programmer pins with the black wire towards the outside of the board, or towards the inside?
Thanks.
