Shapeoko3 - Laser etching mod documented and posted
apspurgeon
Post by apspurgeon » Tue Aug 11, 2015 8:24 am
Hi All
I've been busy getting laser etching set up on my ShapeOko3. The mod is fairly straight forward and allows for a variety of lasers to be attached (solid state lasers - not CO2) that do a great job of etching and cutting. This is based on a similar hack I did for my 3D printer.
The mod uses the unused PWN pins on the control board, some basic electronics / wiring, Inkscape and modified plugins and GRBL Controllers to send the GCode (see instructions).
I've posted it all online, with all the code and instructions and wiring/circuit diagrams.
Warning: If you don't use (all the time) safety glasses you will go blind, period.
No warranties given or implied, your mileage (or KMs) my vary, dipso facto I can play dominoes
Instructions (including links to code downloads)
https://drive.google.com/file/d/0Bz-KxX ... sp=sharing
Wiring
YouTube
https://youtu.be/aQRVkkHdQ7E
Re: Shapeoko3 - Laser etching mod documented and posted
Post by twforeman » Tue Aug 11, 2015 1:14 pm
Cool. Thanks for documenting the project. I've been wanting to put a laser on my Shapeoko.
wunderaa
Post by wunderaa » Tue Aug 11, 2015 4:43 pm
Thanks for throwing this out for everyone! Really appreciate when bright, ambitious folks go the extra mile to document and share their findings with us laymen! :D
FargoPhil
Post by FargoPhil » Tue Aug 11, 2015 6:12 pm
einsteinx2
Post by einsteinx2 » Sun Aug 23, 2015 12:48 am
This is great! Thanks for the write up!
apspurgeon
Post by apspurgeon » Sun Aug 23, 2015 6:20 am
Thanks for the appreciation guys,
Try cutting foam (stamps), and vinyl to make wall stickers is fun and leather....lots of fun (and smells)
richardcn
Post by richardcn » Thu Aug 27, 2015 2:36 am
Amazing,thanks for your share,I will try
apspurgeon
Post by apspurgeon » Thu Aug 27, 2015 4:44 am
This just arrived. Works well cutting foam....Will be off cutting polystyrene this weekend.
it's a nice 31mm circular wand so easy to mount (why I chose it)....price is right too.
A nice profile cut with flow feed rate and single plunge to the depth of the foam should work.
http://www.aliexpress.com/snapshot/6842 ... 5077273838
FargoPhil
Post by FargoPhil » Sat Oct 03, 2015 2:44 pm
I've got the parts and am getting ready to hook up the laser. Are you using the 24v pin in the 6-pin group on the control board?
I've got a 2w laser diode, will that pin be able to handle the current?
Phil
apspurgeon
Post by apspurgeon » Sun Oct 04, 2015 4:33 am
Hi Phil
Yes, I'm taking 24v, PWM and GND from the same connector on the SO3 Board.
I'm using a 2W and not had any issues
