Sparkfun controller
jfdotcom
Sparkfun controller
Post by jfdotcom » Mon Nov 30, 2015 3:25 am
So aside from the obvious changes (no quick connect headers), color, form factor, what are the differences between the Sparkfun controller and the one you guys are shipping?
S3 #342 07/2015
My website
YouTube Channel
Re: Sparkfun controller
Post by WillAdams » Mon Nov 30, 2015 3:38 am
One major difference is it’s opensource: https://cdn.sparkfun.com/datasheets/Too ... ko_v10.pdf
Eagle files: https://cdn.sparkfun.com/datasheets/Too ... ko_v10.zip
Another consideration is whether or not it uses the same comm setup as the Carbide 3D board, so one can use Carbide Motion (they chose to use UGS in their documentation though).
An enumeration beyond that would be good.
kapudon
Post by kapudon » Sun Dec 06, 2015 12:19 am
I've been comparing these. Functionally, I only see two differences:
1) The Sparkfun unit just has one y-axis motor controller (3 total controllers, not 4). The two y-axis motors are wired to this in parallel.
2) The Sparkfun unit has more versatile stepper motor configuration hardware:
Microstepping increment options are 1, 1/2, 1/4, and 1/8 (4-position switch instead of just 2).
Stepper motor current is continuously variable from 1A to 2A using a rotary pot (instead of 2-position switch presetting current for NEMA 17 or 23 stepper coils)
The first is obviously a cost/space saver. The second is to better accommodate DIY builds with odd motors. Neither would really seem to matter if you are going to use a stock S3. I can't see anything else, but would be interested if anybody else does.
Fablicator
Post by Fablicator » Sun Dec 06, 2015 3:12 am
Looks like they us a FTDI rs232 serial-USB which I suspect will be a more reliable connection than the carbide board.
I have multiple 3D printers on the same circuit as my carbide shapeoko 3, and only the carbide board loses connection with turning on/off machinery (router, vacuum, drill press, circular saw)
mrTheWheel
Post by mrTheWheel » Thu Aug 11, 2016 2:17 pm
The Limit switches has build-in RC network and schmit-triggers!
