Unipolar stepper motors
Zeem
Post by Zeem » Fri Jan 20, 2017 7:36 pm
Hello ,
I need an advice as i have Nema 23 Unipolar stepper motor with 6 wire leads and rated current 2A/Phase
and the motor has 4 phrases .
Then i want convert it to bipolar stepper motor as you see in image .
So my question is when i joined the two phrases to each other that's will double current or not for the motor ?
CastIrony
Re: Unipolar stepper motors
Post by CastIrony » Fri Jan 20, 2017 10:04 pm
As long as you're sure there isn't any internal connection between the n/c wires, you should be able to use the other four with a bipolar stepper driver. Never tried it though, so YMMV.
Zeem
Post by Zeem » Sat Jan 21, 2017 12:12 pm
Thanks i already convert to bipolar stepper but i want to know if i double Amp is it ok .
Picengraver
Post by Picengraver » Sat Jan 21, 2017 3:18 pm
This Gecko paper should have answers to all your questions.
http://www.geckodrive.com/support/step- ... asics.html
John
www.picengrave.com
