Shapeoko 3 movement of the Z axis
edruiz
Post by edruiz » Mon Aug 21, 2017 8:49 pm
Hi,
I recently finished assembling my shapeoko 3 and at the moment of testing the movement of the stepper motors with the jog function in the program Carbide motion the motor of the Z axis did not move. I have already checked the connection and everything is according to the assembly guide. After that I tried changing the conector between the X and Z motors and the Z motor moved but the X motor didn’t, so the motor is working fine but I don't know what could be wrong with the connection of the Z motor in the controller board.
Does anyone know what else can I try to solve the problem?
Thank you.
Re: Shapeoko 3 movement of the Z axis
Post by WillAdams » Tue Aug 22, 2017 10:44 am
If you have an XL or XXL, also swap out the extension wiring to test it.
Once you now which part is bad, contact support@carbide3d.com w/ your order/serial # / date of order (or using the e-mail you used to purchase the machine) and we'll work out how to get you the replacement part.
edruiz
Post by edruiz » Tue Aug 22, 2017 5:07 pm
Thanks for the response.
I don't have an XL, I will contact support.
