motionPro 6600 motion controller
johnelle
Post by johnelle » Wed Nov 28, 2018 11:51 am
Announcement/Order: https://www.crowdsupply.com/class-b-pro ... controller
The motionPro 6600 is a four-axes motion controller for stepper motor-driven machines that comes with integrated, high-powered motor drivers. The hardware is designed to be software agnostic and will work with any logic that puts out TTL-level step and direction signals. This expands the scope of applications significantly, since you are not limited to a single, proprietary controller software and can write your own custom software drivers.
The motionPro 6600 is designed to be user-friendly and can be used by anyone, from those with little to no electronics knowledge, such as students, hobbyists, and budding makers, all the way to trained and experienced professionals with backgrounds in engineering and electronics such as professional developers, machinists, and product designers. The controller is designed in such a way that it can adapt to your growing skill levels and demands from increasingly sophisticated machine design.
