SO3 Dropping Connection
allenc
Post by allenc » Sat Feb 02, 2019 1:05 am
When I first started using my SO3, I got lots of connection drops. I was advised to place the SO3 power cable on its own circuit. Problem solved...
However, I find due to wood shop rearrangement, I no longer have a separate circuit I can devote to the SO3. Looks like I'll have to connect SO3 power, spindle power, and PC power on the same 20 amp circuit. I am wondering if any one has experience with simple power cable shielding. Specifically, I'm considering a set of "Anti-interference Noise Filters Ferrite Core Choke Clips."
See this link to amazon for an example (however, clip diameter is too small, will have to research core chokes that will accommodation larger gauge power cables...
https://www.amazon.com/gp/product/B075G ... UTF8&psc=1
Does anyone have ideas/suggestions for shielding? I'm not married to the use of ferrite chokes, just ran across this doing research.
Thanks everyone,
Allen
Re: SO3 Dropping Connection
Post by WillAdams » Sat Feb 02, 2019 6:22 pm
We have a bit on this on the wiki: https://wiki.shapeoko.com/index.php/Ele ... connection
The ferrite beads help --- department of redundancy department I even added a pair to an old Apple cable with a braided wire sleeve.
If you can't resolve things, let us know at support@carbide3d.com and we'll do our best to help.
Colin_barlow
Post by Colin_barlow » Fri Mar 22, 2019 12:49 am
Hi,
i'm a relatively new user of an XXL (Jan delivery) - I was having random stoppages - normally about 20-30 minutes into a job.
I read the wiki/links provided. I use a 1/2 HP dust extractor (i'm a in a woodshop) rather than a shopvac and I remembered that static builds up in the hose and the metal hose wire can ground occasionally via any route it can. I took the tip from the wiki/links and grounded the wire to the main ground bus that the controller etc are grounded on.
Since then I have operated without issues. I guess I was grounding to the router/Z carraige. May not be everyone's fix but seemed to solve mine.
Colin
