batch 4, terminal block goes where?
seigenblues
Post by seigenblues » Mon Nov 19, 2012 7:55 am
Hey all-
Just finished assembling my batch 4 shapeoko, just have to put the electronics together;
I notice on the wiki page (http://www.shapeoko.com/wiki/index.php/ ... ch_4_and_5)
that they recommend mounting the terminal block on the y-axis plate; unfortunately, it seems like the holes shown there are missing on batch 4. Am i missing anything? Where do i mount the terminal block to?
Thanks much,
Batch 4 Shapeoko #837, dual y & dw660
Shapeoko2, TinyG w/ dw660, NEMA23 XY.
T4b
Re: batch 4, terminal block goes where?
Post by T4b » Mon Nov 19, 2012 2:58 pm
It only uses one hole. Is there no single free hole on your Y-Plate? You should be able to use just about any of them as long as the cables are long enough.
I don't know if they changed the plates for batch 4.
ShapeOko #658
There are 10 kinds of people: Those who understand binary notation, those who don't and those who confuse it with ternary.
Post by edwardrford » Mon Nov 19, 2012 3:59 pm
Split the terminal block into 3 sections of 4 (you can use a knife or wire cutters or even scissors). You can't see the Y axis (i cut it off on accident in the picture), but it's mounted in the same place as the X terminal block. The appropriate M3 hardware should be included with your kit.
