twforeman's build
Re: twforeman's build
Post by twforeman » Fri Mar 01, 2013 6:08 pm
Did some more mods the other day.
I moved the Y axis belts to the outside, did the double-X axis mod and mounted my Rigid trim router.
Full details on my blog.
Post by WillAdams » Fri Mar 01, 2013 7:03 pm
Very nice! (esp. the detail photos on your blog).
Could you post the details of the spacing materials you used? It looks like your 2 Makerslide pieces are tight against each other? Did you bolt them together?
Post by twforeman » Sat Mar 02, 2013 2:15 am
You are correct, I forgot to detail what I used for the spacers.
I actually re-did the spacers this evening because I wasn't happy with it. I had to dig around in my parts boxes to find washers of various thicknesses to make the plates the correct distance apart.
I purchased the spacers from McMaster-Carr.
The long spacers on the top are 25mm long and I had to add some washers to get the V wheels to sit down on both rails at the same time.
The long spacers on the bottom are 51mm long and also have additional washers.
I suppose to do it perfectly correctly I should take it all apart do some measuring to figure out what the exact spacer lengths should be and then make some to suit. Sounds a lot like work, especially since what I have seems to be working now. :)
I imagine I'll do it at some point. I can probably take the measurements without disassembling it.
I did not bolt the two pieces of MakerSlide together. I just held them in place and tightened the bolts on the ends. I don't think they are going to go anywhere. If it turns out I am wrong it will be simple enough to add some bolts.
Post by WillAdams » Sat Mar 02, 2013 3:49 am
Thanks.
Someone, (Cat / cvoinescu I think it was) opined that fastening wasn't necessary for shorter lengths, so you should be fine.
I'd really like to see a finite element analysis on what length needs how many bolts at what distance though.
Post by twforeman » Wed Mar 06, 2013 2:56 am
More work on the ShapeOko build. I built a new base for the machine, but I'm not entirely happy how it turned out.
Teaser photo:
Will Winder
Post by Will Winder » Wed Mar 06, 2013 2:05 pm
Those riser's are a great idea, I can't count how many times I've had the Y-Carriages smack into a work piece because I misjudged the amount of clearance.
If you do revisit the base, you might consider a torsion box version like this: http://www.shapeoko.com/forum/viewtopic ... =382#p5263
Mine used 1/2" MDF on the top and 3/4" MDF for the support grid, the result is rock solid.
Post by twforeman » Wed Mar 06, 2013 2:16 pm
The torsion box is a great idea. I'll have to noodle on that a little bit. Thanks!
Post by twforeman » Sun Mar 24, 2013 2:40 pm
A new update in the accuracy front.
I squared up the X and Y axis yesterday, but still have some more work to do.
Building a torsion box table is moving to the top of the list I think.
Post by twforeman » Sun Mar 31, 2013 9:17 pm
More updates. I've been doing all kinds of things to and with my ShapeOko this weekend.
Here is a teaser photo of the air deflector/dust shoe mount I made:
Full details in a LONG blog posting here.
Post by Improbable Construct » Sun Mar 31, 2013 10:20 pm
I have been using craft foam for my new dust shoe and I am pretty happy with it.
It flexes nicely and seems to be fairly sturdy.
