Zerblatt's build
zerblatt007
Zerblatt's build
Post by zerblatt007 » Sun Mar 10, 2013 12:45 pm
My goal is to minimize dust and noise, and still have the rig placed in my loft.
It getting kind of big now, so I will have to take it apart to get it up there.
Enraged
Re: Zerblatt's build
Post by Enraged » Sun Mar 10, 2013 8:45 pm
wow that looks pretty good. What sort of cutting area do you have?
zerblatt007
Post by zerblatt007 » Sun Mar 10, 2013 9:54 pm
Enraged wrote:wow that looks pretty good. What sort of cutting area do you have?
It is not enormous actually. More like 800 x 200 i think.
I'll see if I need more in the X direction later on, as everything is set up so I can extend X from stock makerslides to 500mm ones.
I just wanted more space in the Y direction so it would be easier to place sheets into the milling area.
zerblatt007
Post by zerblatt007 » Wed Mar 20, 2013 9:20 am
Sourced all panels, only need hinges and a few more profiles to tighten the box.. :)
The box will probably vibrate a lot when running, so I plan to insert mats to dampen sound on the plywood walls and rubber feet from a washing machine on the box itself.
zerblatt007
Post by zerblatt007 » Sun Apr 07, 2013 1:20 pm
Got the Kress, but have to fix the house before making the adapter.. :-S
Comparing old to new spindle
Power-supplies mounted with plexiglass.
Post by WillAdams » Sun Apr 07, 2013 2:15 pm
Does the cable drag chain for the gantry interfere w/ travel at the far end of the Y-axis?
Why is it rotated 90 degrees from what's typical?
zerblatt007
Post by zerblatt007 » Sun Apr 07, 2013 7:34 pm
WillAdams wrote:Does the cable drag chain for the gantry interfere w/ travel at the far end of the Y-axis?
It compresses the drag chain a little bit, but I am probably not going to use that part all to the right too often.. :)
It was easier to get the cables where I wanted them that way without drilling to fasten any brackets.
If I take it apart again to extend X, I probably will mount it the normal way.
zerblatt007
Post by zerblatt007 » Sun Apr 07, 2013 7:45 pm
Will it be ok to mount the Kress all the way down by the edge on this 10mm alu piece?
I did want to screw it to the makerslide on the bottom, but I do want the full range also..
Any suggestions?
zerblatt007
Post by zerblatt007 » Fri Jun 14, 2013 9:15 pm
Finally, I get to number the beast: :)
Post by WillAdams » Fri Jun 14, 2013 9:26 pm
zerblatt007 wrote:Will it be ok to mount the Kress all the way down by the edge on this 10mm alu piece?
That's something I've been wondering about,given the oft-noted lever arm effects of raising i\one's machine.
