by Mudshark » Thu Oct 24, 2013 6:26 pm
Here are some gantry pictures. I used all aluminum spacers this time around. The steel wheels are very fickle about alignment. I did get a batch that were too small for the bearings and ended up destroying them.
Below is the bottom of the gantry. It helped to leave off the bottom wheels for the X motor plates so I could rotate. Note: I did swap the X and Y from the original alignment to go to dual X motors, this facilitates some of the software design easier.
- Bottom of gantry.
- DSCF2990.jpg (135.57 KiB) Viewed 2449 times
Next is the front of the gantry. Not a great picture but it shows the Z limit switch which is a SS441A hall effect sensor.
- Front of gantry.
- DSCF2991.jpg (114.54 KiB) Viewed 2449 times
Here is a picture of the Y Axis limit switch, you can see the magnet also. Once again, sorry about picture quality.
- Y Axis limit
- DSCF2993.jpg (111.49 KiB) Viewed 2449 times
Mudshark
Serial #0054, 2 Watt laser, dual X motors, double Y, ACME Z Axis, G540, Mach 3, rotating axis, Proxxon, 750mm x 375mm, laser cross hairs, auto zero
Ordbot #201, MK7 extruder gone minimalist with MK8 nozzle
