Mudsharks' #0054 Upgrade
Mudshark
Re: Mudsharks' #0054 Upgrade
Post by Mudshark » Mon Oct 28, 2013 8:07 pm
Thanks twforeman! I've lurked a lot of your posts here and there. I use a solid state laser that's good for two watts. I posted about it under build log "Another Red Shapeoko". As far as a controller, I just built a box that has a 4pdt 24 vdc relay in it. I put a pair of jacks to connect my DC power supply which I vary in current according to use. The jacks connect thru a steering diode, to the relay which shorts the laser diode when not in use. The relay is controlled by the M3 and M5 commands which are broke out by my G540. I ruined one diode by cycling the power supply so I don't do that anymore. I cut foam for building fishing handles and I also engrave fishing rods with it. 2 watts really limits what you can do. I haven't tried engravoply or the like but etching in wood and corks goes well. Will not do anodized aluminum. My laser is a blue wavelength so the color of material affects power required. Even though it is 2 watts, you still need glasses, believe me.
Mudshark
Serial #0054, 2 Watt laser, dual X motors, double Y, ACME Z Axis, G540, Mach 3, rotating axis, needle cutter, Proxxon, 750mm x 375mm, laser cross hairs, auto zero, GT2
Ordbot #201, E3d hot end, bourdon tube feeder.
Mudshark
Post by Mudshark » Mon Oct 28, 2013 11:55 pm
Here's the crosshairs for locating bit position on the material.
Laser line crosshairs
Mudshark
Mudshark
Post by Mudshark » Wed Oct 30, 2013 12:02 am
Laser cutting new skirts for dust shoe.
Laser cutting dust shoe skirt
Laser cutting
Mudshark
Mudshark
Post by Mudshark » Fri Nov 08, 2013 11:30 pm
Picture cutting 1/8" birch plywood, 15000 rpm 1/16" 2 flute endmill.
Cutting 1/8" plywood
Mudshark
Post by WillAdams » Sat Nov 09, 2013 1:17 pm
Nice! (I have got to get all this freelance stuff out of the way so I can put my machine to work)
What was your feed rate? (for the wiki)
Mudshark
Post by Mudshark » Tue Nov 12, 2013 2:06 am
Feed rate was 150mm, not fast but I ain't either. Probably could go 200 easy. Get back to milling! lol
Mudshark
Post by WillAdams » Tue Nov 12, 2013 11:48 am
Thanks! didn't notice you hadn't specified your cut depth / advance --- 1/32"?
Mudshark
Post by Mudshark » Tue Nov 12, 2013 6:22 pm
Pretty much dead on, 0.8mm. Once again not too speedy but I like to break up my passes by a multiple.
Mudshark
Mudshark
Post by Mudshark » Wed Nov 13, 2013 3:20 am
A short video on Auto Tool Zero function.
Sorry, haven't been able to embed video.
http://youtu.be/z9c8ayULEQo
Mudshark
Enraged
Post by Enraged » Wed Nov 13, 2013 3:30 am
That's pretty cool. Have you tried doing the autozero with your spindle and a tool?
