will1384's Shapeoko 2
Re: will1384's Shapeoko 2
Post by cvoinescu » Tue Aug 26, 2014 10:49 am
Using your multimeter (on volts DC, and if it's not auto-ranging, select the 2 V scale), measure between one of the solder joints circled in red in the image and ground (the screw marked GND on the two-terminal screw connector). Read the voltage, then follow the calculations to find out what the current is. Adjust by turning the small screw-like knob on top of the trimpot. Clockwise is more, counter-clockwise is less. Do not exceed the current rating of your motors, and take care not to touch anything else with the probes while measuring.
sectorix
Post by sectorix » Tue Aug 26, 2014 5:29 pm
cvoinescu wrote:Using your multimeter (on volts DC, and if it's not auto-ranging, select the 2 V scale), measure between one of the solder joints circled in red in the image and ground (the screw marked GND on the two-terminal screw connector). Read the voltage, then follow the calculations to find out what the current is. Adjust by turning the small screw-like knob on top of the trimpot. Clockwise is more, counter-clockwise is less. Do not exceed the current rating of your motors, and take care not to touch anything else with the probes while measuring.
From which 2 points should I measure ? on the bolted bracket on grblshield? a picture would be wonderful
secretspy711
Post by secretspy711 » Tue Aug 26, 2014 8:49 pm
cvoinescu already said it:
Shapeoko 2 #5510: 1200 x 500 mm, Makita RT0701
Post by cvoinescu » Tue Aug 26, 2014 9:48 pm
Yeah, what he said that I said. You had the picture in your own post.
sectorix
Post by sectorix » Wed Aug 27, 2014 1:23 am
Thanks. will try!
obviously new at this
tornwing
Post by tornwing » Thu Apr 30, 2015 4:20 pm
will1384 wrote:Part (4) wiring.
so I think I would need 1.3v on VREF
1.3 / 0.8 = 1.625
Is this correct?
I am going to finish wiring up the stepper motors and testing the CNC control box tonight, lets hope I don't let the smoke out of it :shock: LOL
Hi there
I am a newbie for shapeoko 2 assembly (also electrics).
I just bought gshield board for driving shapeoko 2 before a few months.
As you know, Y axis in SO CNC is driven by two stepper motors .
I looked up this post, if I wanna make stepper motor work efficiently, I have to adjust Verf on Gshield for rated current of stepper motor.
I got the caculation for I=Verf/0.8.
The rated current of my Nama 17s is 1.3A, so I adjusted Verf become 1.035 V (Iref=1.29).
However, in parallel, the currency will become larger. I remember gshield just serve 2.5 A. Once the Nama 17s are paralleled, the total currency (Iref in Y) will become 2.58A to damage Ti8818. Do I get wrong?
Thanks for your help.
Post by cvoinescu » Thu Apr 30, 2015 5:07 pm
Well, sort of. You're right that the rated current of the two motors in parallel will be 2.6 A, but that just means the DRV8818 won't be able to supply the full current. It won't break.
It's unlikely that you'll get close to 2.5 A without some serious cooling. I would simply adjust the reference to the highest current that doesn't cause the driver to go into thermal shutdown in your setup, then dial it back 20% or so.
tornwing
Post by tornwing » Mon May 04, 2015 10:09 am
cvoinescu wrote:Well, sort of. You're right that the rated current of the two motors in parallel will be 2.6 A, but that just means the DRV8818 won't be able to supply the full current. It won't break.
Hi cvoinescu
Thanks for your advice. :D
Because my stepper motor in the X-axis is Nema 23 driving in 2.5A, absoultely, I got the Verf close to 2.0V.
I know Ti8818 cooling is a big issue, so an 8cm fan and fins were prepared.
Thus, I also adjusted the Verf in Y axis almost 2.0.
I am not sure the cooling system is enough or not.
Thank you so much.
cakoceag874
Post by cakoceag874 » Sun Jun 27, 2021 4:00 pm
Jordan 11
Moncler Outlet
Nike Outlet
Nike Shoes Outlet Store Online Shopping
Golden Goose Sneakers Women
Jordans 11 Retro
Jordan 11 Low
Air Max 98
Jordan 11
Air Jordan 11's
Retro 4 Jordans
Mens Nike Shoes
Jordan 5 Retro
Win Like 96
Pandora
Moncler Jackets
Adidas NMD
GGDB Shoes
Jordan Sneakers
Jordan 4
Red Bottoms Louboutin
Jordans Retro
Pandora
Pandora Ring
Air Jordan 11
Air Jordan
Moncler Outlet
Jordan Retros
Retro Jordans
Moncler Jacket
Moncler
Nike Factory Outlet
Air Max 270
Pandora Jewelry Official Site
Cheap Jordan Shoes
Nike Shoes
Women Nike Shoes
Adidas Yeezy
James Harden Shoes
Yeezy Shoes
Golden Goose Outlet
GGDB
Jordan Shoes For Men
Nike Huarache
Jordan 6 Rings
Nike Air Force
Pandora Charms
Jordan Retro 12
Louboutin shoes
Golden Goose Outlet
Soccer Shoes
Moncler Outlet Store
Air Jordan 3s
Red Bottom Shoes
New Jordans 2018
Hermes Birkin
Ferragamo Shoes
Jordan 11s
Yeezy
Pandora Jewelry
Golden Goose Sale
Nike Website
Air Jordan 6
Yeezy
Pandora
Valentino Shoes
Jordan Retro 11
Jordan Shoes
Golden Goose Shoes Women
Jordan Shoes For Women
Jordan 11 GYM Red
Red Bottom Shoes
Moncler Outlet
Nike Snkrs Website
Jordan 12 Retro
Nike Outlet Store
Pandora
Nike Shoes Outlet
Nike Air Force One
Ferragamo Outlet
Jordan Sneakers
Air Jordan Sneakers
GGDB Sneakers
Nike Sale
Golden Goose Mid Star
Nike Outlet
Air Max 90
Jordans Sneakers
Jordan 12
New Jordans 2021
Air Max 95
Jordan Retro 9
Air Max 2018
Air Jordans
Moncler Vest
Jordan 4
Jordan 13s
Jordan 1 Retro
Golden Goose
Jordan 4 Retro
Jordan Retro 3
Moncler Jackets
Fitflops Sale Clearance
Jordan Retro 11 Mens
Pandora Rings Official Site
James Harden shoes
Jordans Retro
Balenciaga
Air Jordan 12
New Nike Shoes 2021
Jordan 8
Pandora
ECCO Shoes For Women
Sneakers Golden Goose
Nike Air Jordan 5
Louboutin Shoes
Fitflop Sandals
Jordan 5s
Air Jordan
Air Jordan 11
Golden Gooses Sneakers
Air Max
Adidas Yeezy
Jordan 6 Retro
Nike Shoes For Women
Jordan Shoes
Jordan 14
Kyrie Irving Shoes
Pandora Jewelry
Adidas NMD
Air Jordan 10
Yeezy Shoes
Fjallraven Kanken Backpack
Balenciaga Sneakers
Pandora Bracelets
cakoceag874
Post by cakoceag874 » Tue Jun 29, 2021 12:11 am
Moncler Coat Men
Asics Gel Kayano
Nike Shoes
Pandora Charms
Yeezys
Outlet Moncler
Pandora Charms
Adidas Website
Men's Nike Shoes
Cheap Jordan Shoes
Pandora Charms
Nike Outlet
Pandora
Pandora Website
Adidas Shoes Men
Pandora Charms
Pandora Jewelry
Asics Outlet Store Online
Pandora Outlet
Jordan 1 Low
Nike Sneakers For Men
Pandora Outlet
Puma Store
Adidas Outlet
Adidas Shoes
Balenciaga
Nike Outlet
Pandora
Pandora Bracelet Charms
Pandora Jewellery
Adidas Outlet
Jordan One
Jordan 1
Nike Store
Pandora Outlet
Nike Shoes Outlet
Best Nike Running Shoes
Air Max 720
Air Jordans 1
Cheap Moncler
Nike Shoes Women
Balenciaga
Pandora Jewelry
Pandora
Nike Air Jordan 1 Retro
Pandora Charms
Asics Running Shoes
Adidas Canada Online
Adidas Canada
Air Jordan 1 Dior
Pandora
Ferragamo Belt
Goyard Bag
Nike Shoes For Men
Pandora
Moncler Outlet
Yeezy 350
Pandora Outlet Online
Balenciaga Triple S
Best Basketball Shoes
Pandora Outlet
Jordan 1's
Jordan 1 Retro
Asics Shoes
Air Jordan 1 Low
Cheap Mens Adidas Shoes
Pandora Jewelry
Pandora Charms
Adidas Running Shoes
Nike Canada
Pandora Jewelry
Pandora Jewelry
Adidas New Shoes
Nike Sneakers For Women
Nike Canada
Asics Outlet
Nike Shoes Women
Balenciaga Sale
Nike Shoes
Pandora Charms
Pandora Bracelet
NMD
Pandora Jewelry
Jordan Wholesale Distributors
Pandora Jewelry
Jordan 1 Low
Goyard Handbags
Ferragamo Belt
Nike Outlet Canada
Pandora Bracelet
Moncler Outlet
Nike Outlet
Pandora Charms
Balenciaga Shoes
Nike Canada
Nike Shoes
Jordan Retro 1
Pandora Jewelry
Nike Store
Pandora Charms
Pandora Charms
Adidas Sale
Pandora
Balenciaga Shoes
Pandora Ring
Pandora Charms
Pandora Bracelets
Asics Sneakers
Pandora Charms
Shoes Ferragamo
Pandora
Ferragamo
Balenciaga
Wholesale Jordan Shoes From China
Nike Outlet Store
Sneakers Adidas
Adidas Yeezy Canada
Wholesale Jordans
Air Jordan 1 Retro
Nike
Pandora Charms
Yeezys
Pandora Outlet
Adidas Shoes For Women
Asics Shoes
Pandora Official Site
Nike Shoes
Pandora
Nike Canada
Salvatore Ferragamo Belt
Moncler Jacket
Cheap Nike Shoes
Moncler Factory Outlet
Jordan 1 High
Adidas Shoes
Moncler Sale
Nike Shoes
Moncler Sale
Nike Canada
