Megesh's Build
megeshg
Megesh's Build
Post by megeshg » Mon May 19, 2014 1:27 pm
Hi All...
A quick introduction, i have been into CNC for close over 3 years now. I have been following the trends and looking at build ideas and just playing around looking to build a cost effective unit. Living in South Africa has caused a lot of issues where a lot of parts had to be imported, which i was trying to avoid. I have been a follower on CNCZone and gained a lot of knowledge from there and started tinkering with a drawer slider based unit. This was a disaster and then i moved onto a wooden design, using parts from designs i saw online i attempted to build a small unit which could mill PCB, i got it going with alu angle and steel bearings but found cutting the wood to precise size and drilling holes that lined up well wasn't working and thus i canned the idea. I played around with normal threaded rod and then tried belted solutions. Each with its pros and cons.
I stumbled on the Shapeoko 1 awhile back and it got quite a negative feeling on the CNCZone, and thus i didnt think much about it, but then i saw what the guys were doing with Shapeoko 2 and the design changes got me really interested! Ever since i have been following this forum everyday! I mainly read and dont post much.
Well onto my build. I decided to go with the shapeoko cause its certainly more rigid than a wood build and took the plunge and started importing parts! Should have done this earlier when the exhcange rate was better :roll:
I decided to only import parts i could have made or source here. So i got Steel wheel, gt3 belting and pulleys, eccentric nuts and smooth idlers from openbuilds. I then had the plates laser cut locally out of 3mm mild steel. I had been given an extrusion set, its a set used to mount solar geysers on roofs. This was the spark to my Shapeoko journey actually. I had a local engineering company make me the steel v guides. This was so far the hardest part.
I then made some changes to the shapeoko design to work with the 40x40 extrusion and given the fact that i could not bolt the carriages directly to the extrusion. So far i have a rough frame put together with a lot work still to come. Will let the pictures explain the rest.
end plates
Y Carriage
megeshg
Re: Megesh's Build
Post by megeshg » Mon May 19, 2014 1:28 pm
4th pic...
Only allowed 3 per a post
Steel wheels
megeshg
Re: Megesh's Build
Post by megeshg » Fri Jul 11, 2014 1:18 pm
Been slow going but getting there...
mock up with motors
megeshg
Re: Megesh's Build
Post by megeshg » Mon Jul 21, 2014 10:27 am
while i wait for more parts to be laser cut, i started looking at the electronics. Alot of people have mentioned thermal shutdown, so i decided i needed to ensure my drivers where cool.
So i mounted them to a heat sink. The big easy drivers have a thermal pad at the bottom which helps dissipate heat, so i used this and attached a heat sink to ensure better heat dissipation.
pcb mounted
pcb mounted with grooves for solder points
megeshg
Re: Megesh's Build
Post by megeshg » Mon Aug 11, 2014 7:21 am
mocked up the z-axis
mock-up z-axis 2
mock-up z-axis 1
megeshg
Re: Megesh's Build
Post by megeshg » Tue Sep 02, 2014 1:38 pm
Busy with electronics enclosure...
adding motor connectors
busy with wiring
briankb
Re: Megesh's Build
Post by briankb » Thu Sep 04, 2014 7:55 pm
Looks great! I picked up some used 40x40 at a surplus store a few months ago. I was going to use it to make an enclosure but I see you are using it and would love to give it a try as the larger version of a CNC to cut foam and sheet goods.
What are those corner pieces you are using to lock it into place and make, what appears to me, a good and accurate square?
How are your guide bearing riding along the 40x40 rails? Could you take close-up picks of that area?
megeshg
Re: Megesh's Build
Post by megeshg » Fri Sep 05, 2014 10:31 am
briankb wrote:Looks great! I picked up some used 40x40 at a surplus store a few months ago. I was going to use it to make an enclosure but I see you are using it and would love to give it a try as the larger version of a CNC to cut foam and sheet goods.
Yeah i also got handed this set so it was perfect to build my machine around.
briankb wrote:What are those corner pieces you are using to lock it into place and make, what appears to me, a good and accurate square?
They are relatively accurate, and also have a centering tab which lines up with the channel in the profile. Prior to tightening i ensure they square with a set square
briankb wrote:How are your guide bearing riding along the 40x40 rails? Could you take close-up picks of that area?
They are riding on a 5mm thick stell plate that has the edges grinding at a 90 degree and have holes drilled along the center line to mount to the extrusion. This was one of the most expensive parts of the build since i had to have engineers make this for me.
megeshg
Re: Megesh's Build
Post by megeshg » Tue Dec 23, 2014 2:35 pm
So my machine i sup and running, and i have made a few things...
Its not perfect but good enough for making a few trinkets.
3d puzzle
star wars fan
My sons name
megeshg
Re: Megesh's Build
Post by megeshg » Tue Dec 23, 2014 2:36 pm
one more pic
my god son, into karate
