Shapeoko3 #1331 - Europe, The Netherlands
stuarttaylor00
Re: Shapeoko3 #1331 - Europe, The Netherlands
Post by stuarttaylor00 » Tue Mar 22, 2016 10:51 am
I love your idea, Its a great way around having to adjust everything for different sized endmills. It's a very tidy solution
Do you lose any travel on the gantry? / Y-axis? It's hard to tell from the pictures if it sticks out past the z-plate
Shapeoko 3 #1095 - Aluminium wasteboard, homing switches, Modified Z plate, Makita 700 router
Flashforge Dreamer Dual extruder 3D printer
2013 Ducati 848 Evo ;)
UltiArjan
Post by UltiArjan » Tue Mar 22, 2016 11:20 am
I loose a little on Y, but that doesn't bother me at all. The setup is easy to remove should I ever need the full Y size.
The setup can probably be made a tiny bit more compact on the left, but I'm not going to be bothered by it now, maybe later... who knows ...
Shapeoko3 #1331, Makita RT0700
Ultimaker2, Ultimaker2+E3Dv6 (abs only)
xfredericox
Post by xfredericox » Thu Mar 24, 2016 12:30 am
i wishmy 3dprinter wouldprint that clean...
http://www.manmademayhem.com
UltiArjan
Post by UltiArjan » Thu Mar 24, 2016 11:18 pm
hmm... actually I consider these prints very rough, just prints with a big 0.6 nozzle and 0.2 layer... normal quality on an Ultimaker is much better....
UltiArjan
Post by UltiArjan » Sat Apr 23, 2016 4:21 pm
Finally managed to replace the printed makita adaptor for a decent aluminium one.
Got some 60mm diameter , 2 mm thick tubing here:
https://www.aluminiumopmaat.nl/aluminiu ... -rond.html
The 2 mm was to much, good not get it in, so I had a company take of 0.25mm on the lathe and now it's a perfect fit. Oh and I obviously had to modify the 60mm diameter , simply cut it open and bend it out a bit.
