World's slowest laser cutter
SnapFracturePop
Post by SnapFracturePop » Fri Oct 19, 2012 2:18 am
"You know, I have one simple request. And that is to have Shapeokos with frickin' laser beams attached to their heads!"
IMGP3419 small.jpg (59.74 KiB) Viewed 4101 times
IMGP3422 small.jpg (83.09 KiB) Viewed 4101 times
Too many of my stories (and letters from the bank) start with the fact that I was bored & in front of my computer with my credit card handy. This time it was a $95 800mw IR laser with TTL control: http://r.ebay.com/mK5NKN from China.
Pretty simple installation - I took an old PC power supply, hooked it to ground & 12v, connected ground & digital pin 12 on the Grblshield to the TTL, focused (~6" away is as close as I can get), and ran. Or tried to, the wire colors were reversed from the standards for the pinouts. Nothing got fried, so I switched them & it worked. The laser won't even mark white paper, but anything with color seems to cut. In this case, black paper plates left over from my 30th birthday party.
IMGP3417 small.jpg (30.87 KiB) Viewed 4101 times
It just runs at 2"/min feedrate.
;Laser cut circle
G20 (inches)
M3 (Start Spindle)
G0 X0.5050Y1.0000 (goto edge)
F2.00 (set feedrate)
G2 X0.5050Y1.0000   i0.4950j0   z-0.0000 (draw circle)
M5 (Stop Spindle)
G0X0Y0 (Origin)
M30 (End of Program)
I can just about get it to cut cardboard at 1"/min. Now to find some designs to cut! My 'Oko has been out of service while I wait on parts (brass standoffs for the Acme Z upgrade & wire connectors for the dual-Y upgrade), so it was nice to get some use out of it while I wait, even if my apartment smells like burning paper.
roberlin
Re: World's slowest laser cutter
Post by roberlin » Fri Oct 19, 2012 12:22 pm
That's awesome!
I'm sure your being very careful, but seriously make sure you don't put your eye out.
SnapFracturePop
Post by SnapFracturePop » Mon Oct 22, 2012 3:09 pm
Everybody loves videos!
And yes, I'm being careful. Nothing reflective on the table, laser only powered when mounted facing down, no unattended cutting, etc. No IR safety glasses, though - they're just too expensive for my budget.
Tom Smith
Post by Tom Smith » Mon Oct 22, 2012 5:38 pm
SnapFracturePop wrote:No IR safety glasses, though - they're just too expensive for my budget.
OK, that just gave me a chill...
Nifty with the laser and all, but I think I will wait to take that step. Invisible high intensity light is not something I am ready to mess with! Be careful, and then more careful...
Tom
_______________
ShapeOko1 191
daveczrn
Post by daveczrn » Mon Oct 22, 2012 11:18 pm
What type of material are you trying g to cut here? Looks like you could use some optics here to get a smaller beam diameter. As well what size is the main circle?
JuKu
Post by JuKu » Tue Oct 23, 2012 5:55 am
Do not look into a laser with your remaining eye!
fito
Post by fito » Tue Oct 23, 2012 6:31 am
Love the video. What software workflow are you using for generating laser friendly gcode? Thanks.
Adolfo Cortés
ShapeOko 649
SnapFracturePop
Post by SnapFracturePop » Tue Oct 23, 2012 7:16 am
The circle's about an inch and a half, and each smaller oval is ~1/8"x1/4". The material is a black paper plate, and I did focus the laser a bit better after this was taken. I had originally designed this as 1/8" tall in Sketchup to cut out of acrylic. I loaded it in CamBam & generated a toolpath with a .001" tool diameter & 1/4" cutting depth so it would only calculate one pass. Then I wrote a PHP script to remove any Z motion & add spindle enable & disable commands whenever it switched from a G1/G2/G3 to a G0 or vice versa. It's not a masterpiece, but it seems pretty good. No guarantees, but try it at http://www.qcgeek.com/laseroko/ or contact me for source code.
I can run it at ~3"/min cutting black paper plates, 0.75"/min cutting cardboard, or all day long without making a mark on white copier paper. I picked up some thin plywood & craft foam but haven't had any time to try them yet.
willo
Post by willo » Mon Apr 15, 2013 5:07 pm
IR blocking plastic is NOT expensive. I suggest getting some. Even matte surfaces can reflect enough light to cause damage. A good option is Lexan. You can get it at HD or online.
