GCODE Step and Alignment Tool
xpix
Re: GCODE Step and Alignment Tool
Post by xpix » Tue Mar 26, 2013 7:46 am
wlanfox wrote:New release v1.1.0
https://github.com/duembeg/gcs/tree/v1.1.0
Awesome! Very good work ... some questions.
* If it possible to edit gcode in future version?
* How can i chnage the font in view gcode window?
wlanfox
Post by wlanfox » Tue Mar 26, 2013 2:40 pm
Hi xpix,
* Editing Gcode is already possible. Just change the Settings->Program un-check read-only in general settings.
* Adding a font settings is in the list of enchantments, But you could change the code in editor.py under InitUI function of class gcsGcodeStcStyledTextCtrl.
abhishek276
Post by abhishek276 » Tue Jul 16, 2013 11:38 pm
Hello xpix,
I am working on a project that requires getting co-ordinates of the pcb from an camera in real time for drilling purpose using Ubuntu OS. So how could I go on with the same. I am all new to this and would be thankful if you help,
wlanfox
Post by wlanfox » Fri Jan 17, 2014 12:26 am
Just an update...
Changed name from gcs to gsat (GCode Step and Alignment Tool) this was done on version 1.3.0. Version 1.4.0 was released and the major highlights are:
* Added support for TinYG
* Added support for Mac OSX
* Changed Jogging panel to have finer control over each axis.
* There is now a G-code msg dialog which allows to change tool and continue program.
https://github.com/duembeg/gsat
wlanfox
Post by wlanfox » Sun Nov 30, 2014 1:52 am
1.5.0 Released
https://github.com/duembeg/gsat/tree/v1.5.0
1.5.0 Changelog
* Added support for TinyG2.
* Added support for Mac OS X Mavericks with working OpenCV.
* Added run time dialog at end of program run (configurable option).
* Added PAUSE state, tool-bar button and menu item, in pause state run time continues.
* Added machine setting for Grbl, TinyG, or TinyG2.
* Added machine setting for initialization script, useful to send setup commands after device connect detect.
* Added machine run time status.
* Added machine Auto Status request setting (mainly for Grbl not needed with TinyG(2)).
* Consolidated Link and Machine setting panels (require a one time reconfiguration of port and baud when upgrading from old version).
* Added jog settings to auto update from machine status.
* Added jog settings to auto request update from machine after jog set operation that don't normally generate verbose information, like set to zero or set to job values.
* Added jog custom button support for scripts.
* Removed second set of XYZ coordinates and enlarge the reminding for ease of view at a distance.
* Updated G-Code message dialog, it is now treated as entering PAUSE state (run time continues).
* Fixed bug with missing variable "serialBaud" not found when changing settings while serial port was open.
* Fixed bug with File->Open being enabled while RUN state was active.
* Fixed multiple UI issues with Mac OS X
* Moved decode of status string processing to program exec thread, this will help UI from becoming temporarily unresponsive.
screenshot
syntaxing
Post by syntaxing » Wed Dec 30, 2015 3:29 pm
wlanfox,
Thanks for your great work! I've been looking for a grbl controller that had a built-in webcam interface so that I can zero the work piece without using an external software align it and offset the tool manually. Your software is perfect!
alhaddar
Post by alhaddar » Thu Feb 15, 2018 6:49 pm
Hello
Does the program work on Windows 10 If yes, what are the steps to work with me?
Regards
