3D CAM Tool Poll
Which CAM Tool do you use?
Hand-coded G-Code
11
6%
Tool-specific plug-in (specify)
2
1%
MakerCAM
41
21%
HeeksCNC
9
5%
PyCAM
8
4%
Carbide Create
15
8%
jscut.org
2
1%
CamBam (commercial)
45
23%
Other Opensource (specify)
6
3%
Other commercial tool (specify)
57
29%
Total votes: 196
3D CAM Tool Poll
Post by WillAdams » Mon Jun 10, 2013 12:30 pm
Vote early, vote often, change your vote as needed.
Re: 3D CAM Tool poll
Post by twforeman » Mon Jun 10, 2013 12:53 pm
I use CamBam mainly for 2D work - pockets and profiles. The couple of times I tried to import an STL file it just seemed to lock up.
I'm currently trying out MeshCam for 3D and I like it. I've also used FreeMill for some 3D work and it seemed to work out alright.
DanMc
Post by DanMc » Mon Jun 10, 2013 2:28 pm
I've been using CamBam too, no problems yet with it on STL files.
I have been wanting to try out DeskProto next. It generally gets good reviews on CNCzone
AnthonyB
Re: 3D CAM Tool Poll
Post by AnthonyB » Wed Jun 12, 2013 12:11 pm
I was pretty underwhelmed with the software that's on offer for CAD/CAM. To me all the available options seem to be either too hard to use, or incredibly buggy, or half-arsed, or some combination of all three.
I started out hand coding g-code, quickly got bored, and started to roll my own "meta" gcode generator, using python (I'm a python programmer by trade): https://bitbucket.org/anthonyb/python-gcode
Currently it can do lines, rectangles (profile and pocket), drilling, 'dogbone' rectangles and circles (again, profile and pocket). Still alphaware-ish, but some might find it useful.
My CAD program is graph paper ;)
Shapeoko #1501 - dual-y axis, double x gantry and a Makita RT0700CX spindle.
Post by WillAdams » Wed Jun 12, 2013 12:27 pm
Yeah, I spent the entire weekend struggling w/ pyCAM and I'm about to give up --- even some things which I'd thought would be simple for it (milling out a cylinder intersecting the side of a cube), it got wrong (the sides of the rectangle separated by the cylinder weren't lined up).
I wonder if there isn't some CAD technique exporting successive .dxf files which would be workable --- but I'll probably go back to Macromedia FreeHand and see what I can do about getting something running which will convert PostScript to G-Code.
Wouldn't be too bad if I could:
- work up a standard way to draw in layers
- script exporting each layer to a separate .ps file
- script converting the .ps file to G-Code
- script concatenating the G-Code (guess I'd have to work out a way to add plunge commands between layers and to lift it out of the pockets)
- open the combined G-code in a previewing tool and refresh
Drawing in FreeHand could be more immediate if I work up a script which will:
- dupe a drawing
- convert each layer to an isometric view stacked <layer height> apart
for a quick preview.
Asymptote does do 3D renderings --- wonder what the internal representation is like. I really wish I could get ImplicitCAD running.
William
Post by WillAdams » Tue Jun 18, 2013 1:24 pm
TonyB
Post by TonyB » Sun Jun 23, 2013 10:51 pm
I figured I'd make a post; maybe it will help me or someone else.
I origionally was using Inkscape and MakerCAM (like everyone else, I think).
I'm just now getting into the need for a 3D tool, both CAD and CAM.
After doing some research and experimenting, I currently have PyCAM installed (this seemed like one of the only CAM Mac solutions?) and I have AutoCAD 2013 installed (though I've been having a really hard getting anything 3D to export as an .stl). I ended up giving up on AutoCAD (for now) and tried TinkerCAD, which worked wonders! It took me like 2 hours to get it figured out; I spent at least 6 hours experimenting with AuotCAD. A friend mentioned that AutoCAD 2013 is ment more for 2D? But that AutoCAD Inventor was ment more for 3D?
I'd like to hear some of the other Mac solutions and people's success. I recently got my PC back (let a friend who didn't have a computer borrow it for a couple months). So maybe I'll do all my CAD work on my Mac, then throw the .stl in my Dropbox folder, walk out to the garage (and have my PC dedicated to the CNC), then pull the file open, recomfirm all my measurements, generate the gCode and run it.
Anyhow, still making progress! Slowly...
Tony
410whp/411ftlbs
Build Thread
Will Winder
Post by Will Winder » Mon Jun 24, 2013 2:46 pm
TonyB wrote:I'd like to hear some of the other Mac solutions and people's success. I recently got my PC back (let a friend who didn't have a computer borrow it for a couple months). So maybe I'll do all my CAD work on my Mac, then throw the .stl in my Dropbox folder, walk out to the garage (and have my PC dedicated to the CNC), then pull the file open, recomfirm all my measurements, generate the gCode and run it.
I installed CamBam on a Windows VM on my Mac.
zerblatt007
Post by zerblatt007 » Mon Jun 24, 2013 3:11 pm
I started with pycam and gave up after a short time.
Tried different CAMs and ended up with Cut2D & Cut3D on a VirtualBox W8 VM on my Mac, as I would like to do cutting with minimal fuzz instead of wrestling with software.
Was hoping for a FOSS solution, but in the mean time I would like to do some cutting.. :)
Llamas
Post by Llamas » Sat Jun 29, 2013 4:16 pm
I've been using FreeCAD and Heeks CAM. Heeks, simply because it was what the tutorial used, and FreeCAD because it pissed me off less than the other potions that also allowed 3D modeling. Actually, OpenSCAD is less frustrating and crash prone than FreeCAD 0.13, but I like the parametric modeling.
I had no prior experience with CAD/CAM.
Sent from my SAMSUNG-SGH-I317 using Xparent BlueTapatalk 2
