3D CAM Tool Poll
Re: 3D CAM Tool Poll
So far, none of the available free CAM options work for me, so I haven't touched my ShapeOko in about 5 months. I want to mill in 3D (smooth curves and generative sculptures), and have yet to find a decent option for that. I do a lot of work with 3D printing, so I am very familiar with a variety of CAD packages, so I can create the STLs and forms just fine. But generating G-code for my ShapeOko to cut has not been possible for me yet.
I recently discovered Autodesk's 123D CNC Utility (http://www.123dapp.com/aboutcnc) and I think it might be good, but I haven't had a chance to try it out yet.
Like I said, I am the proud owner of a functional, but unused ShapeOko simply because I can't generate G-code for the things I want to mill, and don't want to spend another couple hundred dollars for something like CamBam.
How are you generating your sculptures? Have you looked at Processing?zenwebb wrote:I want to mill in 3D (smooth curves and generative sculptures)
http://www.processing.org/
ISTR having seen a G-code generator for it. I'd really like to find an elegant solution for making G-code --- my current best solution is slicing stuff by hand in OpenSCAD, then generating G-code 1mm at a time using MakerCAM. (it might not look too bad if I'd use a ball-nosed bit)
William
(who is looking forward to his wife going fencing this evening so he can run his ShapeOko out on the deck)
I currently have issues with heeks... And all the other software I tried was worse. What do you recommend me to try?
With inkscape and HeeksCNC I can whip out 2D anything in just a couple minutes. It is easy when you stop trying to render faces and just start using sketches as guides for your tool paths. When I first started with Heeks it would crash all the time, but now that I have the method figured out I have not had a single problem. For 3D this does not work. I have tried to use AutoCAD and several other programs and Heeks cannot handle the 3D rendering while creating tool paths and crashes all the time. Also the tool paths that are created are correct and usable about 10% of the time. Not sure where the disconnect is there.
I still have not found anything workable for 3D. I still need to get a good set of mills anyway.
Shapeoko # 1458
Today I downloaded heekscnc and freemill but definitely need some time to learn how to use them.
I have successfully imported a stl or step from solidworks to freemill but not sure what to do from here.
Is it possible to have freemill automatically Generate the code to cut out the part I designed? From what I was able to do, it looked like I had to essentially re- build all the surfaces, solids, and cuts using the imported stl or step geometry as my guide. But that seems pretty time consuming. This is just a rectangular piece with some holes cut out and a few grooves that are cut half the material thickness deep.
Any tips for importing step or stl files into freemill and getting it to spit out g code? Heekscnc was not running very well for me and was freezing frequently so I spent more time with freemill today.
Shapeoko2 #3702:
I had to cast an "Other Pro" vote since discovering DeskProto. I've not had time to fully research all the hobby-licensed offerings but this software is brilliant at only $340 US for a full-featured 2D, 2.5D, and mult-axis CAM tool. I'm only discovering its abilities but it appears to do everything all the open-source and freebie software does and provides an expansion path towards more sophisticated machining techniques.
Oh! And, did I mention bitmap operations?
And, like the big tools, operations can be layered atop each other.
So I wonder: Why is there so little opinion expressed about this software on forums like CNCZone, etc? I would expect the hobby CNC world to be exploding about this.
Michael
Michael
Shapeoko 2 + Bosch Colt mount . PreciseBits ER20 1/8" & 1/4" collets . stock electronics in a custom control box.
I use the vectric lineup, cut2d and cut 3d. Im working on adding bobcad v24 to my line up. Mostly for the lathe support (new lathe en route) but i plan to see what it can do with 2&3d work.
Brian
Shapeoko 2 #I have no idea
I have not yet ordered a CNC mill but will probably do so today or Monday.
I did buy a Printrbot Simple 3D printer to play around with which, by definition needs 3D STL files. I am still on the low side of the learning curve so no expert but have had good success with Google Sketchup ( plugins provide stl output ) and LibreCAD.
Not having a CNC macine yet I understand that while the printer "Adds" what you want the mill "takes away" what you don't want meaning I assume the software actually driving the mill is working reverse of what a printer would be doing. Still, the files are .stl so assume any 3D Cad program would do for the design of parts.
Thoughts?
Thoughts?
Correct, for the 3D design, anything which will make a file which can be converted to .stl will work.
For CAM, one needs a tool which is able to ``slice'' a design into suitably thin layers and which has options for setting the appropriate ``infill'' for a given part. See http://reprap.org/wiki/RepRap_Options#Slicing_Software for a list of suitable tools --- because it's a different technique, the tools are quite different from what we list at http://www.shapeoko.com/wiki/index.php/CAM#3D
Heeks CNC allows for 3D profile milling in a pretty straight-forward way. (That seems to be only obscurely documented, if at all).
With GRBL .8c, I have keep the feed rates low to make sure that the Z-axis doesn't try to traverse too fast during compound movements, but with .9b I'm hoping to put that limitation to bed.
Note that there are some bugs. If I put other operations before the attach, operations after the detach are skipped (well, cause Python to throw an exception). In a few cases, I've also had the toolpath include the drilling of a hole to the final depth at the start of the attached pocket operation. I think it may happen when the framing sketch overhangs the edge of the object, but by less than the diameter of the end mill. I'll get around to debugging that one eventually...in the meantime, it shows up in the visualization, and can be edited out of the gcode by hand.
- Import a 3D object.
- Orient it so the surface you want to profile is oriented up.
- Create a sketch outlining the area you want to profile.
- Select the 3D object.
- Create an attach milling operation.
- Select the sketch.
- Create a pocket milling operation.
- Select use zig-zag.
- Select other values as appropriate.
- Create a detach milling operation.
- Generate the gcode.
