Convert EPS to toolpath
droo
Post by droo » Mon Sep 23, 2013 11:14 am
Hi all,
After some help here - I am trying to convert this eps to a toolpath in CAMBAM.
I can convert the file no problem to a DXF however this does not come out right as all the underlying shapes are present ?
Can anyone offer any advice or workflow so I can make my son a clock for his birthday :-)
Drew.
newthomas.ai.zip
(53.13 KiB) Downloaded 90 times
Re: Convert EPS to toolpath
Post by WillAdams » Mon Sep 23, 2013 12:12 pm
We do have a PostScript to G-Code converter listed on the wiki:
http://www.shapeoko.com/wiki/index.php/ ... Generators
http://www.chiark.greenend.org.uk/~alanb/ps2gc.html
and I'd thought I'd found a .eps to G-Code converter on Google Code.... (it's the other way 'round --- look for gcode2eps, and of course there's pstoedit)
Since you're starting w/ a .ai file, why not save out to .svg from AI and use MakerCAM?
droo
Post by droo » Mon Sep 23, 2013 12:16 pm
Thanks for the info - will take a look at the options given :-)
Drew.
droo
Post by droo » Mon Sep 23, 2013 12:29 pm
Perhaps I am missing the point here but what I am looking for is an easy way to take this vector and then convert just the outline to a toolpath.
When exported as a DXF it looks like the attached file - is there no way to "Flatten" the vector image in to a simple set of paths ?
Drew.
Post by WillAdams » Mon Sep 23, 2013 12:41 pm
Yes, but you should do that in Adobe Illustrator --- select each set of color paths in turn and union them --- then punch out anything which was missed.
Post by WillAdams » Mon Sep 23, 2013 12:46 pm
Looking at how it's put together, the easiest thing probably would be to work from the bottom up --- cloning paths, unioning them and then subtracting elements as needed.
droo
Post by droo » Mon Sep 23, 2013 12:58 pm
Looks like I best get the Adobe manual out - never used illustrator !
Drew
Post by WillAdams » Mon Sep 23, 2013 1:10 pm
Learning to use Illustrator is an agony I wouldn't wish on anyone. Here's a flattened / unioned / punched file suitable for 2.5D carving:
newthomas_k.ai.zip
(90 KiB) Downloaded 95 times
For those who don't have Illustrator, it looks like this:
Screen shot 2013-09-23 at 9.17.56 AM.png (14.71 KiB) Viewed 3540 times
droo
Post by droo » Mon Sep 23, 2013 1:22 pm
That is Amazing - and thank you very much.
I will investigate the tools you mention in Ai as I expect my little ones brother is going to want a clock making when he see's his brothers.
Drew.
Post by WillAdams » Wed Sep 25, 2013 1:47 am
You're welcome!
I'd suggest trying Inkscape or Cenon instead of Illustrator.
