Trouble adjust cutting speed
ColeHolloway
Post by ColeHolloway » Wed Jul 16, 2014 12:14 am
Hi everyone.
I am trying to cut some soft plastic with my shapeoko, and the speed of the shapeoko when cutting is going far to fast to make a accurate cut. I have successfully adjusted the default seek and feed of the shapeoko by manually changing the F, $4, and $5, but this only affects the speed of the machine when it is traveling to the next cut point, not the speed of the shapeoko when it cuts.
I am using the universal g-code sender with a macbook pro. Does anyone know how I can change this setting?
Re: Trouble adjust cutting speed
Post by WillAdams » Wed Jul 16, 2014 12:53 am
The feed rate is adjusted in your CAM tool --- what did you use?
See http://www.shapeoko.com/wiki/index.php/CAM for more options.
More information at http://www.shapeoko.com/wiki/index.php/Endmills and http://www.shapeoko.com/wiki/index.php/ ... s#Plastics
ColeHolloway
Post by ColeHolloway » Wed Jul 16, 2014 2:25 am
I make the G-code in cambam, and then export it using the universal G-code sender (http://www.shapeoko.com/wiki/index.php/ ... ode-Sender) It seems like the 3 settings for feed rate, F, $4, and $5 only change the speed of the shapeoko when it moves from cutting point to cutting point, the speed changes to a constant rate whenever it begins to cut. Is the cutting feed rate adjusted in the gcode?
Auarhau
Post by Auarhau » Wed Jul 16, 2014 7:28 am
Yes, the feed rate (cut speed) is defined in the G-code, which means you have to set this value in CamBam. Probably you are using a default feed rate value in CamBam which is way too high. Open up your code and look at the value behind F. Like this: G1 Z-1.0000 F125.0 means this cut will move -1mm in the Z direction at 125mm/min. Check out the feeds and speed section of the wiki to get an idea of what settings you should use for your material.
The seek speed you set in grbl is as you have figured out already, the speed at which the machine moves between points when not cutting. There is also a default feed rate parameter in the grbl configuration ($4 I believe for Grbl 0.8), as you have discovered. Don’t mind this setting really. Leave it at the wiki default of 500. This setting only comes in to play if your G-code has no feed rate defined. And your G-code should always have a defined feed rate for every operation, thus making the default grbl feed rate setting kind of useless.
Post by WillAdams » Wed Jul 16, 2014 10:17 am
Grbl's default feed rate is not just useless, but downright anomalous, since other g-code interpreters don't define it.
fl0yd
Post by fl0yd » Wed Jul 16, 2014 12:38 pm
WillAdams wrote:Grbl's default feed rate is not just useless, but downright anomalous, since other g-code interpreters don't define it.
It's also deprecated in v.9
Fl0yd
ColeHolloway
Post by ColeHolloway » Wed Jul 16, 2014 2:51 pm
Auarhau wrote:Yes, the feed rate (cut speed) is defined in the G-code, which means you have to set this value in CamBam. Probably you are using a default feed rate value in CamBam which is way too high. Open up your code and look at the value behind F. Like this: G1 Z-1.0000 F125.0 means this cut will move -1mm in the Z direction at 125mm/min. Check out the feeds and speed section of the wiki to get an idea of what settings you should use for your material.
This solved my question! thanks Auarhau!
