Need help getting aspire to work with shapeoko2
scott
Post by scott » Sat Sep 13, 2014 2:23 am
I am new and i need all the help i can get. my machine run great with the "hello world" program. but i tried to run my own file and it works, but i put in for it to be 7" by 11" inches.....but when i run it, it cuts it all out with-in a two inch square......can anyone please help?
dataway
Re: Need help getting aspire to work with shapeoko2
Post by dataway » Sun Sep 14, 2014 1:19 am
Hi Scott I use Aspire with my Shapeoko 2 and it works great I am also running TinyG instead of GRBL . I could have a look at your gcode if you want to send it over and see if I can determine what is causing the issue. Also confirm what controller you are using..
John
Improbable Construct
Post by Improbable Construct » Sun Sep 14, 2014 11:56 am
Are you working in inches or mm? If your machine expects mm and you drew in inches it could cause the sort of problem you are describing.
ALuomala
Post by ALuomala » Mon Sep 15, 2014 2:16 am
Did you get the SO2 post-processor for Aspire? Here is the link for the post-processor (link) and here is instructions for where to place it (link).
ShapeOko2, serial ??
DW660 spindle;
Upgrades: 900mm X axis and 1000mm Y axis; ACME Z Axis; modified MDF wasteboard with t-slot
Primary usage: wood crafting (signs, plaques, and ultimately a CNC-made electric guitar)
Schruminator
Post by Schruminator » Mon Sep 15, 2014 5:44 pm
I'm using Aspire and GRBL and it works awesome. I'm not sure exactly what is causing your issues (posting the g-code may help-- rename the end of the file from .nc or .gcode to .txt for posting on this forum if I recall)-- but it'll be worth the hassle once you get it sorted. It's an amazing program.
Also, for sure make sure that you have the ShapeOko post processor as ALuomala mentioned. I haven't bothered using the other options, but I understand they were sometimes buggy with the SO2.
