Homing switches.... workflow
jdunne
Post by jdunne » Sun Nov 23, 2014 4:46 pm
So I am about to install 3 switches, for x, y, z... to use as homing switches... I totally get the concept. But I don't understand how to then use the home position to determine the proper z depth for the workpiece? I see some videos showing using a metal contact plate to then set Z zero. But I assume there is a "decent" workflow using homing switches, and also getting the z depth right. Since most users seem to be using their Shapeoko without the electrically measured contact plate.
Is there a good tutorial somewhere showing both how to use homing switches to set the machine 0,0,0 and then cut the part? I see several users setting the homing position. But i don't see the next step using this position relative to the actual workpiece?
Joe
Re: Homing switches.... workflow
Post by twforeman » Sun Nov 23, 2014 10:10 pm
Start by reading this. http://www.shapeoko.com/wiki/index.php/ ... te_Systems
If you still have questions ask them here.
I'm your huckleberry...
Sent using Tapatalk
Ender 3 3D Printer
