High-speed machining with Autodesk Fusion 360
tbfleming
Post by tbfleming » Sun Dec 14, 2014 9:37 pm
I decided to try Fusion's 30-day trial. Here's how it did:
This is at 5000 mm/min, 10mm deep, 1/8" router bit
RobCee
Re: High-speed machining with Autodesk Fusion 360
Post by RobCee » Sun Dec 14, 2014 9:57 pm
Very interesting. I have not checked out actually using Fusion 360 for any real work yet.
The HSM looks great for roughing, but not so great for finishing. It appears that you get a lot of deflection in your spindle and some odd artifacts in your tool path.
Good job on playing with it though, I look forward to seeing more examples!
tbfleming
Post by tbfleming » Mon Dec 22, 2014 11:08 pm
Here's an example of when things go wrong (slow-mo):
I set it up for the wrong cutter diameter. Config = 1/4", Actual = 1/8". Red Oak.
cmason
Post by cmason » Sat Jan 10, 2015 5:29 pm
Hey tbfleming,
Can you describe a little more detail about what you've done here?
What sort of step over ("optimal load") are you using? Any strategy for picking this? Could you share your grbl settings? (In particular curious about accelerations.)
I have a similar setup I think: 0.9g, Dewalt 611 in custom mount, Acme Z, otherwise stock. Any non-obvious machine mods on your end?
I've been using a more conventional/conservative strategy (~60-90 in/min, diameter / 2 stepdown / over) and I'm going to experiment with more aggressive options.
I'm really liking Fusion. It's the first program I've found (for the mac at least) that gets me from concept to construction in one go.
Thanks for sharing!
-c
