I need some advice on workflow. Up until now, I've just been cutting basic shapes with Easel. I would like to use SolidWorks to design projects. However, I'm confused on how to go from Solidworks to milling.
This is what I've got so far:
Solidworks-> ? -> MakerCAM -> UniversalGCode
My questions are:
Is this correct?
Is there a file format I can save my Solidworks parts into that I can import directly into MakerCAM?
Should I even use MakerCAM?
Confused on workflow
Shapeoko 2 Serial #7341. Relatively stock. Custom sound/dust enclosure. 24V 15 amp power supply.
Re: Confused on workflow
MakerCAM is intended to accept SVG files, say from Inkscape as documented here: http://www.shapeoko.com/wiki/index.php/Software
Basically what one does is:
- CAD --- design file, save a file which one's CAM tool will accept
- CAM --- accepts design files, creates G-Code
- Comm/Control --- sends G-Code to the machine
ISTR that Solidworks has some sort of integrated CAM option --- check the forums and the commercial page on the wiki: http://www.shapeoko.com/wiki/index.php/ ... l_Software
I don't know much about MakerCAM, so I don't know if it does 3D or not, but my work flow would be export the part from SolidWorks as an STL file and then use MeshCAM or FreeMIll to generate the 3D surfacing g-code.
FreeMill is actually free and works surprisingly well.
I thought Freemill was a plugin that only worked in conjuction with a couple of CAD pkgs.twforeman wrote: FreeMill is actually free and works surprisingly well.
mg
FreeMill requires you to install VisualCad, but you don't need to buy a license for it. It works pretty well too.
