Hello rodcar125,
I just saw your post about the Shapeoko Postprocessor for NX,
I am currently working on doing so as well,
could you please share the .pui file?
thanks in advance, I appreciate your help
(I am currently unable to send private messages since I registered recently)
NX 9 CAD/CAM & Post
Re: NX 9 CAD/CAM & Post
compwizard7 wrote:Hello, I am interested in an NX post as well. Was there any progress made with this? I also can't figure out how to PM you for the post to test.
Chase
Chase, sorry for the late response. I must have missed your post.rtype107 wrote:Hello rodcar125,
Of course I will send you the post if you still want it and you to you too rtype107
Please send me an email to cardenas125 at gmail and I'll reply you with the file.
Last week I've made some modifications to the post for it to print, as comment, the program name at the beginning of the file and for each operation the name and tool used. You can also select if you want to print a M06 if there's a toll change or not.
Good day!
If you’re satisfied that this works well, why not post it to the wiki?
If you’re not willing to do that, change the file extension to .txt and put it up here?
I can upload it here, changing the file extension, as you suggested. Thanks WillWillAdams wrote:If you’re satisfied that this works well, why not post it to the wiki?
Here's the NX post for S3 files.
I've been using it with NX 9.0.3.4 and works great. Any problems or mods regarding the post please let me know so I can work on them or add it to the post.
I have tested and run parts with it (3D and 2.5D) but again, I'm not responsible for any problems it might generate when using it. Please verify your code first.
Instructions:
Download all 3 files and rename them as follows (make sure you remove the number after the _GRBL in the file name):
NX_Shapeoko3_GRBL1.txt ---> NX_Shapeoko3_GRBL.def (18Kb)
NX_Shapeoko3_GRBL2.txt ---> NX_Shapeoko3_GRBL.pui (66Kb)
NX_Shapeoko3_GRBL3.txt ---> NX_Shapeoko3_GRBL.tcl (124Kb)
Save them to a known path and from NX load it in the Post process dialog window, (this has to be done every time you start a NX session) If you would want to pertmanently add the post to the post list on the dialog window you need to install it first with the install NC post processor button under the tools ribbon.
If you do not save the .def and .tcl files in the same directory as the .pui NX will run into an error when post processing
And as final note, the post will always print an M06 code when a tool change is due unless specified unchecking the check-box in the tool change settings menu of the operation dialog box thats named Manual Tool Change
Happy milling!
Rod
Instructions:
Happy milling!
Rod
Sorry for the late response but thanks a lot!!!!!
