NX 9 CAD/CAM & Post
rtype107
Re: NX 9 CAD/CAM & Post
Post by rtype107 » Sat Oct 24, 2015 12:29 am
Hello rodcar125,
I just saw your post about the Shapeoko Postprocessor for NX,
I am currently working on doing so as well,
could you please share the .pui file?
thanks in advance, I appreciate your help
(I am currently unable to send private messages since I registered recently)
rodcar125
Post by rodcar125 » Sun Oct 25, 2015 2:56 am
compwizard7 wrote:Hello, I am interested in an NX post as well. Was there any progress made with this? I also can't figure out how to PM you for the post to test.
Thanks,
Chase
rtype107 wrote:Hello rodcar125,
Chase, sorry for the late response. I must have missed your post.
Of course I will send you the post if you still want it and you to you too rtype107
Please send me an email to cardenas125 at gmail and I'll reply you with the file.
Last week I've made some modifications to the post for it to print, as comment, the program name at the beginning of the file and for each operation the name and tool used. You can also select if you want to print a M06 if there's a toll change or not.
Good day!
Post by WillAdams » Sun Oct 25, 2015 10:06 am
If you’re satisfied that this works well, why not post it to the wiki?
If you’re not willing to do that, change the file extension to .txt and put it up here?
rodcar125
Post by rodcar125 » Mon Oct 26, 2015 2:54 pm
WillAdams wrote:If you’re satisfied that this works well, why not post it to the wiki?
I can upload it here, changing the file extension, as you suggested. Thanks Will
rodcar125
Post by rodcar125 » Mon Oct 26, 2015 3:49 pm
Here's the NX post for S3 files.
I've been using it with NX 9.0.3.4 and works great. Any problems or mods regarding the post please let me know so I can work on them or add it to the post.
I have tested and run parts with it (3D and 2.5D) but again, I'm not responsible for any problems it might generate when using it. Please verify your code first.
Instructions:
Download all 3 files and rename them as follows (make sure you remove the number after the _GRBL in the file name):
NX_Shapeoko3_GRBL1.txt ---> NX_Shapeoko3_GRBL.def (18Kb)
NX_Shapeoko3_GRBL2.txt ---> NX_Shapeoko3_GRBL.pui (66Kb)
NX_Shapeoko3_GRBL3.txt ---> NX_Shapeoko3_GRBL.tcl (124Kb)
Rename to .def
(17.07 KiB) Downloaded 186 times
rename to .pui
(65.45 KiB) Downloaded 158 times
rename to .tcl
(123.01 KiB) Downloaded 158 times
Save them to a known path and from NX load it in the Post process dialog window, (this has to be done every time you start a NX session) If you would want to pertmanently add the post to the post list on the dialog window you need to install it first with the install NC post processor button under the tools ribbon.
If you do not save the .def and .tcl files in the same directory as the .pui NX will run into an error when post processing
And as final note, the post will always print an M06 code when a tool change is due unless specified unchecking the check-box in the tool change settings menu of the operation dialog box thats named Manual Tool Change
Happy milling!
Rod
rtype107
Post by rtype107 » Mon Dec 28, 2015 2:12 am
Sorry for the late response but thanks a lot!!!!!
