Hi,
I've got my Shapeoko 2 feed rate set to 60, and when it is cutting it is moving according to that value. But when the machine is moving the spindle to a target position above the stock without cutting, it moves too slow. I was wondering if there is a way to tell it to move faster when it is not cutting as this is wasting a lot of time. I am using Vectric aspire.
Slow movement when not cutting
Re: Slow movement when not cutting
Hello,
You'll have to show us your GCode...
Shapeoko #736
And a dump of the grbl settings, because that's where your rapid rate is set.
Shapeoko #1,123
Thanks, seek rate is what I was looking forHans wrote:And a dump of the grbl settings, because that's where your rapid rate is set.
