Slow movement when not cutting
oskanaan
Post by oskanaan » Mon Apr 06, 2015 8:06 pm
Hi,
I've got my Shapeoko 2 feed rate set to 60, and when it is cutting it is moving according to that value. But when the machine is moving the spindle to a target position above the stock without cutting, it moves too slow. I was wondering if there is a way to tell it to move faster when it is not cutting as this is wasting a lot of time. I am using Vectric aspire.
PsyKo
Re: Slow movement when not cutting
Post by PsyKo » Mon Apr 06, 2015 8:08 pm
Hello,
You'll have to show us your GCode...
Shapeoko #736
Hans
Post by Hans » Mon Apr 06, 2015 10:10 pm
And a dump of the grbl settings, because that's where your rapid rate is set.
Shapeoko #1,123
oskanaan
Post by oskanaan » Thu Apr 09, 2015 6:34 am
Hans wrote:And a dump of the grbl settings, because that's where your rapid rate is set.
Thanks, seek rate is what I was looking for :) I've changed it from 500 mm/min to 1000 mm/min and it looks much better now!
