Upvotes if you use Fusion 360
atrueresistance
Post by atrueresistance » Fri Apr 24, 2015 3:37 pm
Fusion 360 IdeaStation: Request a Feature or Enhancement
With enough upvotes, they may implement.
Shapeoko Post Processor
http://forums.autodesk.com/t5/fusion-36 ... -p/5607103
Shapeoko 1 #unknown
Shapeoko 3 #572
Checkout my Etsy Store
pepik
Re: Upvotes if you use Fusion 360
Post by pepik » Sat Apr 25, 2015 2:05 pm
Shapeoko 2 #7266
DW660 spindle
Upgraded wasteboard
Drag Chains
scott216
Fusion 360 Post Processor
Post by scott216 » Sat May 02, 2015 2:03 am
I took the grbl post processor that comes with Fusion and modified it for Shapeoko. I got rid of the G28 command and replaced it with a z-axis move to the clearance height. I also moved the code that sets the work coordinates earlier in the program so the work coordinates are set before any move commands are sent. See attached.
shapeoko post processor.zip
(4.88 KiB) Downloaded 295 times
Shapeoko 2 with DW660
grbl v0.9g
PCB Toolchain: Cadsoft Eagle > pcb-gcode > Chilipeppr or GRBL Panel
Other Toolchain: Fusion 360 > Chilipeppr or GRBL Panel
My Build Log
chomdh
Post by chomdh » Mon Nov 30, 2015 4:13 am
So this will raise the Z height before traversing to the first feature? If so, thank you, and I need to try this ASAP. Anything I generate with Fusion will rapid to the first feature without lifting the Z.
Shapeoko2 #3702:
