I use the Universal GCode Sender. It was the one on the instructions when I built the S2.
Re: Communication/Control Software Poll
Posted: Sat May 02, 2015 1:13 pm
by Woodworker
I thought that was what this was all about.
Posted: Sat May 02, 2015 4:38 pm
by cvoinescu
Okay, I don't see why it makes a difference to the intent of the poll -- you count ChiliPeppr and Easel as a vote for "internet required", and everything else as a vote for "no internet required", and spelling it out should not make a difference -- but I put it back, because it was not polite of me to barge in and edit Will's poll.
Posted: Sat May 02, 2015 5:15 pm
by chamnit
@cvoinescu : Will solved this issue by starting a new poll based on this question. I don't think matters what this poll says at this point. Thanks though.
I just tried to use it but it looks like Grbl doesn't finish booting, because when I try to jog, nothing happens. If i close it and open Universal G-code Sender, the CNC moves fine.
Any suggestion?
Posted: Mon Dec 14, 2015 3:16 am
by cvoinescu
grep wrote:I just tried to use it but it looks like Grbl doesn't finish booting, because when I try to jog, nothing happens. If i close it and open Universal G-code Sender, the CNC moves fine.
Any suggestion
The wrong baud rate setting can cause that. The correct setting for GRBL 0.9x with the default configuration is 115,200.
Posted: Mon Dec 14, 2015 3:43 am
by grep
Thanks, but it´s set up at 115200. (It´s the same in UGS afaik). Is anyone getting it to work? I'm on Linux Mint Rafaela. I'm in the dialout group already (same for UGS also). I don't have to compile anything right, just download the tar.gz, extract and double click on grblctrl? Is it possible i have some dependencies/librairies missing? Thanks.
