What happens when the laptop goes to sleep?
woodworkerbob
Post by woodworkerbob » Mon Jul 13, 2015 7:14 pm
I was running a 20+ minute job, and not paying attention to the computer, when the router stopped moving. Until that point, the job had been running correctly.
I saw that my laptop had gone to sleep, and required me to log in before I could get to the Carbide Motion screen. If the computer goes to sleep, does that stop the sending of commands to the SO3 controller?
Bob
SVEMakerSpaces
Hans
Re: What happens when the laptop goes to sleep?
Post by Hans » Mon Jul 13, 2015 7:38 pm
Sleep is sleep. Under control panel > power options > "change when the computer sleeps" you can set the computer to never put itself to sleep. (Windows)
Shapeoko #1,123
woodworkerbob
Post by woodworkerbob » Mon Jul 13, 2015 7:42 pm
Hans wrote:Sleep is sleep. Under control panel > power options > "change when the computer sleeps" you can set the computer to never put itself to sleep. (Windows)
Yea. Just wanted to confirm. I just hoped that an active job might keep the machine "awake".
Bob
SVEMakerSpaces
Post by WillAdams » Mon Jul 13, 2015 7:45 pm
woodworkerbob
Post by woodworkerbob » Mon Jul 13, 2015 9:15 pm
Thanks for the help and the suggestions.
Bob
SVEMakerSpaces
RobCee
Post by RobCee » Tue Jul 14, 2015 9:32 am
If you are using a Mac, you can setup HotCorners to keep it awake.
I reverted to using a power supply instead of battery and forcing it to stay awake. Sleeps were causing many problems for me in the early days.
Post by cvoinescu » Tue Jul 14, 2015 1:02 pm
RobCee wrote:Sleeps were causing many problems for me in the early days.
Yes, sleeps are the worst. I could do so much more with 6-8 extra hours every day. -- What? Not that kind of sleep? Oh. Never mind, then. :)
MeanderBolt
Post by MeanderBolt » Wed Jul 15, 2015 1:24 am
Yeah, sleep killed a couple hour aluminum job once. Once it was back on, I found that it had lost it's zero, and the piece was not recoverable. I have a small pile of things that didn't end well, and that was added to it. I tried, but getting a machine re-aligned without any sort of homing is not going to happen.
Shapeoko 2 # 3569 - DW660
Build log
