Carbide Create
jwisbell35
Re: Carbide Create
Post by jwisbell35 » Thu Dec 10, 2015 8:47 pm
Has anyone got CC to work in Windows 10? Have tried several times but it will not open....
aztecnology
Re: Carbide Create
Post by aztecnology » Thu Dec 10, 2015 10:09 pm
I am able to open it, but it is still very buggy in my experience. Text vector has never worked for me for example. Looks like a new update is out today so I will give it another courtesy look, but I'm pretty much on to VCarve and doubt I will be looking back.
On a side note, I think I've lost a couple pulley set screws, anyone know where I can get some replacements? Dimension/Size?
Shapeoko 3 #1055
dogsop
Re: Carbide Create
Post by dogsop » Thu Dec 10, 2015 10:17 pm
Will Carbide Create work with the Shapeoko 3 which is being sold through Sparkfun? If so, will be get a license if we purchase through that channel?
Re: Carbide Create
Post by cvoinescu » Thu Dec 10, 2015 11:08 pm
dogsop wrote:Will Carbide Create work with the Shapeoko 3 which is being sold through Sparkfun? If so, will be get a license if we purchase through that channel?
Carbide Create generates G-code in a proprietary format that's compatible only with Carbide Motion. Carbide Motion, in turn, looks at the IDs of the USB-to-serial chip, and works only if they match the Carbide Motion board. The SparkFun board uses an altogether different chip, so unless Carbide 3D add that to the list of supported IDs, it will not work.
So it's entirely up to Carbide 3D.
AnonymousPerson
Re: Carbide Create
Post by AnonymousPerson » Fri Dec 11, 2015 4:33 am
aztecnology wrote:On a side note, I think I've lost a couple pulley set screws, anyone know where I can get some replacements? Dimension/Size?
This seems to be them:
http://www.shapeoko.com/wiki/index.php/ ... ulleys.jpg
Maybe email Carbide 3D to ask if they can send a few out to you?
Re: Carbide Create
Post by WillAdams » Fri Dec 11, 2015 12:17 pm
Pulley set screws should be available from any decent hardware store.
http://www.shapeoko.com/wiki/index.php/ ... ment_Parts
josejuako
Re: Carbide Create
Post by josejuako » Thu Jan 14, 2016 10:48 pm
New video Carbide :idea: very nice .
https://www.youtube.com/watch?v=X6-fSnkluaA
J
Shapeoko 3 Serial No. 1302
Shook
Re: Carbide Create
Post by Shook » Fri Jan 15, 2016 1:41 am
Wow....I may have to give that a second look. I was using F-engrave for my V-carving and engraving, but have been struggling a bit adding a profile to an engraving to cut it to size (ended up using a bandsaw which is probably faster, but less precise).
Shapeoko 3 (#1107)
jbc
Re: Carbide Create
Post by jbc » Sat Jan 16, 2016 5:17 pm
I'd like to see a feature in Carbide Create that would help when cutting aluminum.
Slotting on the SO3 is tough when cutting aluminum. Lots of heat and pretty difficult for a machine that isn't too ridged.
If Carbide Create could make profiles with tabs using an adaptive cutting approach you could increase speeds and extend tool life and avoid slotting difficulties.
Andrew has a video showing the adaptive approach which never runs into a slotting issue like a typical profiling cutting approach;
https://www.youtube.com/watch?v=SOvgP6ScfrM
jbc
jbc
VCarvePro 8
3D Printing prototypes
Sketchup
http://www.CaffeineMachine.com
Jimf
Re: Carbide Create
Post by Jimf » Sun Jan 17, 2016 6:16 am
I'm pretty sure fusion360 has adaptive Trochoidal cutting if you want to try that now. It may take awhile for Carbide Create to have that feature. A lot of CAM programs don't even do it yet, some of them been around for years such as Vectric.
