Fusion 360 lift z before first traverse?
DRobs86
Post by DRobs86 » Wed Dec 16, 2015 6:04 pm
I've started using fusion 360 can and I am very happy with it with the exception of how it starts programs. In every operation that starts a program it wants to rapid to the start of the cut from stock height (z equals 0). If the surface has any curvature to it or I set the Z zero a little bit to hard into the stock I am going to end up with a tool skim mark on the stock. It wants to rapid to the first cut, lift z, and then plunge or ramp.
I don't see anything in setup that handles this. I also have no problem when it moves between operations (say from boring to pocketing to a profile op) in the same program... Only on the first operation. I manually correct this, but it is annoying.
Any advice?
Fablicator
Re: Fusion 360 lift z before first traverse?
Post by Fablicator » Wed Dec 16, 2015 6:09 pm
Are you using homing and a WCS?
chomdh
Post by chomdh » Wed Dec 16, 2015 6:16 pm
I had the same issue. I found a shapeoko2 specific post processor that I now run with F360 and it does a z lift before traverse as expected.
Let me see if I can find where I downloaded that from.
edit: you can get the shapeoko post for F360 here: http://www.restrictedayerspace.net/cnc/ ... -shapeoko/
Shapeoko2 #3702:
DW611, arduino uno, gshield v5, NEMA23's on X & dual Y, NEMA17 on Z with ACME rod, 9mm belts, Mean Well NES-350-24V power supply, re-inforced gantry rails.
Soon to have inventables spindle mount and 1M X axis.
Post by WillAdams » Wed Dec 16, 2015 7:00 pm
There are several listed here: http://www.shapeoko.com/wiki/index.php/ ... are#3D_CAD (and I've added the one you linked)
chomdh
Post by chomdh » Wed Dec 16, 2015 7:10 pm
Yay I made the wiki!
The link I posted loads extremely slow so be patient.
Shapeoko2 #3702:
DRobs86
Post by DRobs86 » Thu Dec 17, 2015 5:36 pm
I am not using homing and WCS.
I have been using the grbl post processer but I will look into this Shapeoko specific one (are they the same?).
chomdh
Post by chomdh » Thu Dec 17, 2015 6:38 pm
I was using the F360 "grbl" post (which never did a +z before the initial move) until I came across the shapeoko specific one I linked to. So they are not exactly the same. The shapeoko post is doing a +z for me before the initial move, as expected.
Shapeoko2 #3702:
