Carbide Motion Crash
TargetOfGravity
Re: Carbide Motion Crash
Post by TargetOfGravity » Mon Jan 04, 2016 4:59 am
So I think I resolved my issue. The g-code exported from MakerCam is
Code: Select all
(Generated by PartKam Version 0.05)
G20 G90 G40
(profile 1)
G0 Z0.5
T0 M6
G17
M3
G0 X4.6578 Y4.4669
G1 Z-0.039 F20
G2 X4.6997 Y4.4763 I0.2997 J-1.2452 F45
G2 X4.7523 Y4.4863 I0.4036 J-1.9642
G2 X4.8051 Y4.495 I0.3494 J-1.9652
G2 X4.8473 Y4.5006 I0.1856 J-1.235
G3 X4.8622 Y4.5024 I-0.4656 J4.028
G3 X4.8744 Y4.5038 I-0.3206 J2.6866
G3 X4.8864 Y4.5054 I-0.1753 J1.4142
G1 X4.8872 Y4.5055
(only the first portion) as an example. Notice that comments are included and the G20, G90 and G40 are all on the same line. Editing the file to this:
Code: Select all
G20
G90
G40
G0 Z0.5
T0 M6
G17
M3
G0 X4.6578 Y4.4669
G1 Z-0.039 F20
G1 X4.8872 Y4.5055
resolved the issue.
Winanszero
Post by Winanszero » Mon Jan 11, 2016 4:11 am
UGS has done this for me in 1.08 and 1.09 as well. I find that if I'm jogging the spindle manually and change from Inches to MM, then hit Send, sometimes the g-code will be scaled down just as the jogging steps were. I can cancel the run and change back to Inches, then resend the file and everything resumes as normal.
Shook
Post by Shook » Wed Jan 13, 2016 5:43 pm
I ran into this with UGS on a few occasions. I've created unit-specific Z-probing macros that explicitly change to G20 / G21 based on the file I'm about to run. With that as part of my normal workflow, I don't run into the issue any longer.
Shapeoko 3 (#1107)
