Trochoidal milling with Estlcam and Shapeoko 3
Estlcam
Post by Estlcam » Fri Jan 15, 2016 8:45 pm
Hi,
Ive just completed a video explaining trochoidal milling with Estlcam:
Trochoidal milling improves performance for aluminum, steel, cast iron and other difficult materials.
It even allows to cut stainless steel with quite good results.
I hope it is Ok to post this here - if you have any questions just ask me.
Christian
Re: Trochoidal milling with Estlcam and Shapeoko 3
Post by WillAdams » Fri Jan 15, 2016 9:02 pm
Very, very cool.
This is also called HSM, right?
Would you care to share a road map of the features which you plan to implement?
RoguePirin
Post by RoguePirin » Fri Jan 15, 2016 9:23 pm
That looks great! Can Estlcam work on Linux, or is it Windows only software?
Post by WillAdams » Fri Jan 15, 2016 9:48 pm
Windows only, but there’s been a report of getting it to run on Linux on the Inventables forum.
josejuako
Post by josejuako » Fri Jan 15, 2016 11:57 pm
I have seen almost all the software and the only thing I liked is Estlcam , for that reason I have driven forum Shapeoko 3.
Thank you Christian , I know I am successful in my search !.
Look at my previous post !.
J
Shapeoko 3 Serial No. 1302
AlainTernet
Post by AlainTernet » Sat Jan 16, 2016 1:54 am
Very interesting, nice feature !
Estlcam
Post by Estlcam » Sat Jan 16, 2016 1:25 pm
WillAdams wrote:This is also called HSM, right?
To be honest I'm quite confused about the terminology myself.
As far as I understand it HSM (high speed machining) is more or less an "umbrella term" for several methods with trochoidal milling just being one amongst others.
Also trochoidal milling itself is a rather loose term - there are quite distinctive implementations with different levels of sophistication.
WillAdams wrote:Would you care to share a road map of the features which you plan to implement?
Estlcam is more or less a pastime for me with no definite goal - suggestions are always welcome.
At the moment I'm adding translation support so users can translate it to their language.
RoguePirin wrote:Can Estlcam work on Linux, or is it Windows only software?
Windows only unfortunately. Some people managed to get it running under Linux - but all report it cost them hours to days and many failed completely.
There is unfortunately no easy step by step guide and I personally have basically no Linux experience myself.
