Roughing and finishing, again
sjj47
Post by sjj47 » Tue Feb 09, 2016 8:56 pm
I know 3D CAM programs have explicit strategies for roughing and finishing, but right now I'm still struggling with 2D and 2.5D.
Suppose I'm cutting a simple pocket 50mm x 50mm x 5mm deep. I want to do a fast, rough pass with a large bit and a slow, finish path with a smaller bit.
Is there any software out there (free or otherwise) that will set these paths up automatically? Ideally, I'm looking for some CAM program where I can define the pocket, define the bits, and the rough margin. Then the CAM program generates the gcode file (or files) that cuts the rough pass, pauses for a tool change, and then cuts the final pass.
Of course, what I want is that the final pass does not simply repeat the pocket milling operation, and spend most of its time cutting air. I want the final pass to only mill the material left behind by the roughing pass.
I guess I could more or less do this manually, by defining the gcode for the pocket rough cut first, and then defining a finish path with a lower surface starting point (MakerCAM lets us do that). But does anyone know of a CAM program that handles it all?
If not, how do other folks handle the roughing and finishing process?
Re: Roughing and finishing, again
Post by twforeman » Tue Feb 09, 2016 9:27 pm
Most CAM programs support this.
CAMBam does it for sure.
You might need to do the roughing pocket, followed by a finish pass at full depth to get the floor and and finish profile to get the walls.
xfredericox
Post by xfredericox » Tue Feb 09, 2016 9:28 pm
i think rhinocam has that feature. Rhinocam is not cheap though.
But why the need for a tool change? I'm not an expert but the machine 'should' be precise no matter what. You risk bad alignment in an effort to improve finish quality. Sounds like a contradiction to me.
http://www.manmademayhem.com
RoguePirin
Post by RoguePirin » Tue Feb 09, 2016 9:40 pm
Although not cheap, Vectric's software does this:
  • VCarve Desktop ($349 / £235 / €330)
  • VCarve Pro ($699 / £470 / €660)
  • Aspire ($1,995 /£1,295 / €1,800)
I don't know about their "Cut 2D" line of products.
Estlcam
Post by Estlcam » Tue Feb 09, 2016 9:55 pm
Estlcam has this feature for pockets - it is described in the video from 5:06 on:
sgth0mas
Post by sgth0mas » Wed Feb 10, 2016 3:20 pm
VCarve has a very user friendly way of doing this.
Im sure other cam packages do as well.
