Getting an error about unsupported command
pinkfish
Post by pinkfish » Wed May 04, 2016 10:20 pm
Here is the log from bcnc. This all works in carbide motion, but for some reason carbide motion completely freezes about 18% of the way through the file. It has worked with larger files before... But with this one, 18% in it freezes. So I tried bcnc and now I get this error, but all the commands look suppored from what I can see? The one it seems to be saying is not supported is a g0?
David.
G90G0X7.06339Y10.9162
ok
[G0 G55 G17 G21 G90 G94 M0 M5 M9 T0 F0. S0.]
ok
G90
G20G90G91.1G64G40
G0Z0.125
M3S1000
G0X3.75Y0.25
G0Z0.125
G0X3.8125Y0.25
ok
G0Z0.0625
error: Unsupported command
ok
ok
ok
ok
ok
vasilis
Re: Getting an error about unsupported command
Post by vasilis » Thu May 05, 2016 7:01 am
Itis the G64 that is causing the problem.
Post by cvoinescu » Thu May 05, 2016 10:43 am
It is the G64. Note that exactly one 'ok' or 'error' response occurs after each G-code line sent to GRBL -- but not necessarily immediately after. There are as many responses as there are lines, though, so you can count them to match them up.
Post by WillAdams » Thu May 05, 2016 11:39 am
raidoh
Post by raidoh » Thu May 26, 2016 7:06 pm
Pinkfish, Where did you find the bCNC log file (in Windows7)? I'm getting a similar "unsupported command" error in bCNC using g-code from F-engrave.
Post by WillAdams » Thu May 26, 2016 7:31 pm
raidoh
Post by raidoh » Fri May 27, 2016 2:32 am
I did. I noticed the default G code header is defined with the G64 culprit, "G17 G64 P0.001 M3 S3000". Deleting the line from the code and the Header Settings fixed it.
Post by WillAdams » Fri May 27, 2016 2:56 am
