[fusion360]plunge & tabs
plastik
Post by plastik » Mon May 16, 2016 8:16 am
Hi,
I am using fusion 360 + chilipeppr to operate my cnc router.
I didn't look into into my g code files but I'm pretty sure that cutting tabs is performed at full feed rate, even when plunging and retracting.
Do you confirm this ?
Is there any settings in fusion 360 to set a lower speed when plunging for the tabs?
OX CNC 750x500 - Makita Rt0700 - TinyG controller
Worklflow : Fusion 360 + Chilippepr
France
aam
Re: [fusion360]plunge & tabs
Post by aam » Mon May 16, 2016 1:55 pm
How about changing the Plunge Feedrate in the Tool tab?
plastik
Post by plastik » Mon May 16, 2016 5:10 pm
My bad, after checking into the G code files, plunges when cutting tabs are indeed performed at plunge feedrate...
France
CrazyBillybob
Post by CrazyBillybob » Mon May 16, 2016 6:48 pm
not to side track this thread too much. But did you figure out a way to to tabs automagicly in Fusion360? I've been adding them in by hand if there is an auto function it would save me time.
MidCitySlim
Post by MidCitySlim » Mon May 16, 2016 10:37 pm
In Fusion 360 when you are performing a 2D Contour, you can add tabs at distance or at points. It's on the Geometry Tab...
Screenshot 2016-05-16 15.35.10.png (65.75 KiB) Viewed 1261 times
CrazyBillybob
Post by CrazyBillybob » Tue May 17, 2016 2:37 pm
Thanks,
I will have to give that a try on my next project.
CBB
