Fusion 360
D@DENNIS.COM
Fusion 360
Post by D@DENNIS.COM » Wed Jan 04, 2017 3:10 am
Would anyone know if it is possible to Post a CAM project from 360 so Carbide Motion can run it?
Thank You
CrazyBillybob
Re: Fusion 360
Post by CrazyBillybob » Wed Jan 04, 2017 3:26 pm
I have a Shapeoko 2 so I'm not using Carbide motion. But I know from other threads that you can use the Standard Grbl post processor for Fusion 360 then sent the output file to the Shapeoko 3 with UGS or other similar g code senders.
Hopefully someone with a Shapeoko3 that uses Fusion can comment on the use of Carbide Motoion and Fusion 360.
Hope this helps at least a little.
CBB
Re: Fusion 360
Post by WillAdams » Wed Jan 04, 2017 3:39 pm
There are some links / text / commentary on this on the wiki: http://www.shapeoko.com/wiki/index.php/ ... are#3D_CAD
Shook
Re: Fusion 360
Post by Shook » Thu Jan 05, 2017 3:46 am
I use Fusion 360, but haven't used Carbide Motion in quite a while. I use a $35 Raspberry Pi 3 with Universal G-Code Sender. That way I don't worry about the dust in a more expensive laptop.
There is a shapeoko post for Fusion 360 - see this thread - http://www.shapeoko.com/forum/viewtopic.php?f=16&t=6328
Shapeoko 3 (#1107)
bharbour
Re: Fusion 360
Post by bharbour » Fri Jan 13, 2017 2:50 pm
I'm learning Fusion 360 and have a few question regarding the 3D pocket clearing settings. I see somethings I'm not familiar with like Surface Speed, Feed Per Tooth, Lead-In Feedrate, Lead-Out Feedrate Ramp Feedrate, Feed per Revolution. I've been using MakerCAM and haven't seen these settings. Can some of these be ignored or do they all have to have a value set?
Ric
Re: Fusion 360
Post by Ric » Fri Jan 13, 2017 3:30 pm
Shook,
Could you give a few more details about how you use the Raspberry Pi? I'm specifically wondering if you have a monitor hooked up to it, as well as internet connection. My son suggested I go that route, but I haven't because I'm not sure what the setup would be like.
thanks.
Shook
Re: Fusion 360
Post by Shook » Sun Jan 15, 2017 5:20 am
I have a Raspberry Pi 3 with a cheap LCD and a bluetooth mouse/keyboard (https://smile.amazon.com/Rii-Smartphone ... +bluetooth)
In general, I will browse the network and copy down the file to it.
I'm running Universal GCode Sender on it.
In my personal opinion, I prefer the Raspi over a laptop for the CNC because I'm not worried about dust and aluminum chips getting into an expensive laptop. With that said, I hate touch pads (like the one on the keyboard above) that register taps instead of buttons. It's too easy to accidentally tap on a button while moving the mouse.
Edit: I originally grabbed the bCNC image to run the CNC, but for various reasons, I've never been successful with bCNC. I REALLY wanted to like it for probing and auto levelling. In the end Universal GCODE Sender works best for my needs
Shapeoko 3 (#1107)
Ric
Re: Fusion 360
Post by Ric » Sun Jan 15, 2017 2:55 pm
Thanks--I'll probably get one. I also don't like using my nicer laptop.
I run bCNC because UGC wouldn't work on some files (on my mac). I'll try UGC to see how it works on the Pi.
afkrejci90
Re: Fusion 360
Post by afkrejci90 » Thu Jan 26, 2017 1:51 am
Fusion 360 has a post processor for carbide motion. Under Post Configuration select carbide3d.cps and leave all other setting at default. As far as using carbide motion, there's quite a bit to be desired yet in the software.
