Recommendation for 5 axis CAD/CAM milling using NUM controll
JoeClark
Post by JoeClark » Mon Oct 30, 2017 1:16 pm
Hello Everyone,
I've started to learn Fusion 360 but it seems that this is not the ideal software for my application.
This is an example of work I need to mill. Typically I will be given a 3D file from Soildworks/Inventor and have to mill moulds.
What do you think is the best software for tool part creation? My controller is a NUM system
Recommendation for 5 axis CAD/CAM milling using NUM controller-img_1643-jpgRecommendation for 5 axis CAD/CAM milling using NUM controller-mould-foil-jpg
Is there anything that I should consider when choosing software?
Any Idea , Suggestions would be appreciated,
Thanks,
I didn't find the right solution from the internet.
References: http://www.cnczone.com/forums/uncategor ... tware.html
DanMc
Re: Recommendation for 5 axis CAD/CAM milling using NUM cont
Post by DanMc » Sun Nov 05, 2017 9:25 pm
You might have a look at DeskProto, they have a hobbyist license which is reasonable. Apart from that everything I've seen is in the thousands for 5 axis and I have zero experience in that area. DeskProto is limited in how the 4th and 5th axis work so make sure it's compatible with your machine.
