Plunging
jlangemak
Plunging
Post by jlangemak » Thu Mar 15, 2018 3:20 pm
I've been milling quite a few different types of materials and I've noticed that sometimes the machine plunges once, and then just advances deeper while other times the machine will cut at one depth, withdraw, and then plunge again for each new depth it has to cut to reach the target.
What decides this? Is it the type of material I select? Or the bit? Fully withdrawing to the retract height each time sure slows things down.
Thanks! - Jon
Re: Plunging
Post by WillAdams » Thu Mar 15, 2018 3:53 pm
Could you let us know:
- which CAM program you're using?
- what material(s) this involves?
- what settings cause the differing behavior?
I suspect it's either a bug, or a lack of optimization.
