All the scaling is wrong. Heekscad and inkscape
kf4mot
Post by kf4mot » Sat Nov 24, 2012 4:23 pm
What am I doing wrong here?
Opening the DW660 dxf file in inkscape and it shows up about 1 inch wide.
Same file in Heeks shows up less than 0.11 inch wide.
Both are wrong but not sure why and what the solution is?
https://github.com/shapeoko/ShapeOko/tr ... r/upgrades
rpe
Re: All the scaling is wrong. Heekscad and inkscape
Post by rpe » Fri Dec 07, 2012 8:49 pm
I'm having the same problem with Heeks. Cambam works fine but my trial period is running out.
kf4mot
Post by kf4mot » Fri Dec 07, 2012 10:07 pm
Heeks just seems really temperamental to me.
Some days it works fine and other days not so much.
My scaling problem went away when I started using my own drawings.
Now today it can't make tabs properly while it was working fine earlier?
fito
Post by fito » Sat Dec 08, 2012 12:17 am
Heeks and Inkscape are really dodgy with dxf files. I have found that using other software to load the dxf and exporting a new dxf file really helps out. I am using Librecad for that. By loading a 'buggy' dxf into LibreCad and exporting to dxf has relieved quite a few dxf import issues with Heekscnc.
Just my personal experience with Inkscape and Heekscnc. Unfortunately I haven't found out how to convert to paths with LibreCad, but I can't say that I have really tried to as yet. It does move up the list as Heekscnc seems to like dxf files that are all paths and Heekscnc does produce decent gcode. It just needs an optimizer to help speed up the execution of the gcode.
Adolfo Cortés
ShapeOko 649
fito
Post by fito » Sun Dec 16, 2012 7:25 pm
It just occured to me that the scaling issue may be units of measure related. If you save the dxf in inches and open it in mm the scaling would be off from the expected.
Adolfo Cortés
ShapeOko 649
kf4mot
Post by kf4mot » Wed Dec 19, 2012 1:30 am
All my work is in inches.
I have noticed when I save as a "big blue" dxf it scales wrong but if I use the inkscape default dxf it scales fine.
